Fuel Pump/ Vacuum hose questions |
LCOX |
Jun 11 2020, 09:38 AM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
I need to replace the 3 port fuel pump on my 74 914. Can I use an aftermarket 2 port pump? If so who sells a good one
Also who sells vacuum hoses. Looking for a complete pre-cut package with all sizes included and pre cut to the correct length. |
dr914@autoatlanta.com |
Jun 11 2020, 10:12 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you can replace the three port with the 75 76 just need to replace a hose get a late fuel filter and clamps and pad the omega clamp with rubber, then modify the plug. If an original equipment type guy you can get the rebuilt pump of which we stock PLENTY. the vacuum hose kit is pre cut with a diagram and all continental hoses but they are now not as colorful as the originals
I need to replace the 3 port fuel pump on my 74 914. Can I use an aftermarket 2 port pump? If so who sells a good one Also who sells vacuum hoses. Looking for a complete pre-cut package with all sizes included and pre cut to the correct length. |
Frankvw |
Jun 11 2020, 10:33 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
did you see my how-to post:
http://www.914world.com/bbs2/index.php?showtopic=345333 maybe it helps.... |
Lo-Fi Version | Time is now: 1st June 2024 - 09:29 PM |
