| The Double S |
Jun 14 2020, 12:45 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 8-October 19 From: Upland, CA Member No.: 23,545 Region Association: Southern California |
Hi All,
I have a 1970 914 with an aftermarket Dino steering wheel. I've had issues with the turn signal cancel and the horn not working since I purchased the car. When I removed the steering wheel and adapter to investigate, it seems like the cancel tab is not long enough to fully initiate the cancel mechanism in the turn signal. It feels like it just touches it half way but still leaves the turn signal on. Is this a result of the tab on the cancel ring being worn out? Or is it the steering wheel adapter fitment preventing the tab to go as far as it needs to? Additionally, my horn doesn't work. I attached a picture below. It looks like the brass colored arm has been removed or sheered of. Will that affect the performance of the canceling tab? Thank you for the help in advance. ![]() |
| 914Sixer |
Jun 14 2020, 01:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,469 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Early cars are SPECIAL. You might be able to get away with this switch. You will have to make sure wiring matches up though or get creative. Pull screws and see if the back matches up. Click on screen shot to open up
Attached thumbnail(s) |
| porschetub |
Jun 14 2020, 04:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,090 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi All, I have a 1970 914 with an aftermarket Dino steering wheel. I've had issues with the turn signal cancel and the horn not working since I purchased the car. When I removed the steering wheel and adapter to investigate, it seems like the cancel tab is not long enough to fully initiate the cancel mechanism in the turn signal. It feels like it just touches it half way but still leaves the turn signal on. Is this a result of the tab on the cancel ring being worn out? Or is it the steering wheel adapter fitment preventing the tab to go as far as it needs to? Additionally, my horn doesn't work. I attached a picture below. It looks like the brass colored arm has been removed or sheered of. Will that affect the performance of the canceling tab? Thank you for the help in advance. The broken contact is the reason you have no horn as you have no contact on the slip ring,this is usually cause but no lube,the tab wears and breaks off. Not sure about the Dino wheels but suspect they are same fitment as the Momo version,what adaptor do you have ? and do you have the stock slip ring attached on the back of the adaptor or something else ?. Seems like your wheel may not be on far enough for the cancel function to work or switch is broken,however you still need to replace it . I found for example the Momo adaptor wasn't a great fit so the stock wheel components didn't fit well without some work to get the cancel piece in the right place. Good luck. |
| porschetub |
Jun 14 2020, 04:29 PM
Early cars are SPECIAL. You might be able to get away with this switch. You will have to make sure wiring matches up though or get creative. Pull screws and see if the back matches up. Click on screen shot to open up Is this an early car ? as I notice it has the later gauge panel... (IMG:style_emoticons/default/confused24.gif) . |
| The Double S |
Jun 14 2020, 11:06 PM
QUOTE The broken contact is the reason you have no horn as you have no contact on the slip ring,this is usually cause but no lube,the tab wears and breaks off. Not sure about the Dino wheels but suspect they are same fitment as the Momo version,what adaptor do you have ? and do you have the stock slip ring attached on the back of the adaptor or something else ?. Seems like your wheel may not be on far enough for the cancel function to work or switch is broken,however you still need to replace it . I found for example the Momo adaptor wasn't a great fit so the stock wheel components didn't fit well without some work to get the cancel piece in the right place. Good luck. I don't know what adapter I have. The car came with the setup that is currently on it. The ring has VW stamped on it. There is a large E-clip that prevents the wheel from moving too far down the splines. I've seen that E-clip on the threads with guys installing MOMO wheels. Wasn't sure if there is a ring with a longer tab on it. Thanks for the part number, I'll check the connector. I'm more bothered by the cancel tab than the horn Lol. |
| The Double S |
Jun 14 2020, 11:16 PM
Early cars are SPECIAL. You might be able to get away with this switch. You will have to make sure wiring matches up though or get creative. Pull screws and see if the back matches up. Click on screen shot to open up Is this an early car ? as I notice it has the later gauge panel... (IMG:style_emoticons/default/confused24.gif) . Yes, it is a 1970. It was converted to a 350 SBC and I'm finding many parts that aren't early model and must have been swapped along the way. |
| dr914@autoatlanta.com |
Jun 15 2020, 08:57 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,234 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
your pic is of a 75 76 model with the horn contact tab broken off
Hi All, I have a 1970 914 with an aftermarket Dino steering wheel. I've had issues with the turn signal cancel and the horn not working since I purchased the car. When I removed the steering wheel and adapter to investigate, it seems like the cancel tab is not long enough to fully initiate the cancel mechanism in the turn signal. It feels like it just touches it half way but still leaves the turn signal on. Is this a result of the tab on the cancel ring being worn out? Or is it the steering wheel adapter fitment preventing the tab to go as far as it needs to? Additionally, my horn doesn't work. I attached a picture below. It looks like the brass colored arm has been removed or sheered of. Will that affect the performance of the canceling tab? Thank you for the help in advance. |
| The Double S |
Jun 16 2020, 12:53 AM
Is there a ring available with a longer tab?
| ClayPerrine |
Jun 16 2020, 06:48 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Is there a ring available with a longer tab? All you can do is buy a new turn signal switch. The missing tab acts as a spring loaded contact that slides against the turn signal ring on the back of the steering wheel. Without it, the horn will never work. And they can't be bought separately. |
| The Double S |
Jun 16 2020, 09:27 AM
Sorry, I wasn't clear. I meant a longer tab on the turn signal cancel ring. Looking at pictures online some seem to protrude out longer leading me to believe that the tab has deteriorated from use? Has anyone seen that before?
Is the E-clip behind the splines stock to the car or would it have been installed with the steering wheel adapter? |
| The Double S |
Jun 17 2020, 05:48 PM
Example of what I am talking about below. Perhaps a later model turn signal and cancel ring tab was needed to accommodate the steering wheel and adapter.
This is what I have currently on my adapter: ![]() This is PT# 914.347.835.00 which appears to have a longer cancel tab. It is listed as an early model part: ![]() |
| The Double S |
Jun 23 2020, 02:51 PM
Anyone have experience in this area with steering wheel adapters and turn signal cancel rings?
| 914sgofast2 |
Jun 23 2020, 07:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
| The Double S |
Jun 23 2020, 08:15 PM
Thanks gofast2. I had the same idea with the washer fix you mentioned. Glad to know it will work.
| PCH |
Jun 24 2020, 01:36 PM
Member ![]() ![]() Group: Members Posts: 147 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California
Could you point out in the picture where you put the washers?
| The Double S |
Jun 24 2020, 08:41 PM
Could you point out in the picture where you put the washers? I haven't done it yet, but in theory if you put flat washers on the screws behind the cancel ring, on the back side of the steering wheel adapter, it will be just enough to catch the cancel ring tab on the turn signal mechanism. The screws in questions are the phillips screws in the picture below. The washers would have to be between the black cancel ring and the back of the adapter. ![]() |
| PCH |
Jun 25 2020, 05:44 PM
Thank you for the close-up and your help. I'm going to give the washers a try.
| The Double S |
Jun 27 2020, 10:22 PM
Update: I put 3 flat washers on each screw that mounts the cancel ring to the steering wheel adapter. It is cancelling intermittently now.
The tab on the cancel ring isn't hung up on anything I can see. Tomorrow I am going to try to see if just one or two washers per screw will work better. |
Lo-Fi Version | Time is now: 25th April 2026 - 03:32 PM |
