Things heating up, temps going hot on a cool night, brakes? |
nditiz1 |
Jun 14 2020, 05:24 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Took the silver car out for a cruise after getting the Rennline pedal board installed. It seemed things were OK until I got on the highway to open up. The CHT started to rise at an unsafe level so I pulled over. Dropping from 5th to 4th only helped temporarily. I noticed the clutch grab was very high. I am wondering if the clutch wasn't fully releasing, but I dont think this would cause additional heat only additional slippage? I have since adjusted it. Im more concerned with the brakes as it seemed when I came to a stop the car did not slow to a coasted unassisted stop but more so as though light braking was being applied. None of the wheels felt more hot than the rest. The new pedal assembly I put in was set to the same length as the old but maybe further adjustment is needed. I noticed it was tough to move into the garage one night as though the brakes were applied. That combined with the ebrake not having a crisp click click click leads me to believe something is going on. I did jack the rear up and was able to turn both wheels with little force and noticed some slight dragging, expected right? I need to check the fronts for ease of spin.
Other Ideas? |
914e |
Jun 15 2020, 07:19 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I would check that the brake pedal is allowing the master cylinder to fully return.
porschetub |
Jun 16 2020, 12:17 AM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yep sticking master cylinder piston or...semi siezed calipers or swollen brake lines,most likely rubber brake lines ,cheers.
nditiz1 |
Jun 16 2020, 06:55 AM
@914e - this was it. Even though I set the rod to the same as the old pedal cluster, the new had all new bushings and rubber stops. After loosening the rod and moving it back I no longer had any slight brake pressure. The car rolled with ease. Took it out for a spin an no overheat requiring a pull over. Temps were still on the high side, but that could be from timing, to missing cooling tin, or valves not set properly. Thanks all!
ConeDodger |
Jun 16 2020, 07:35 AM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Having had lots of experience with a CHT gauge and a Type IV I can tell you that in a perfect world, they don’t like 5th gear cruising. Not enough fan speed I suspect. Just shifting from 4th to 5th you can watch the temp go up quickly.
nditiz1 |
Jun 16 2020, 10:46 AM
yeah, it was a cool night (75), on a flat stretch of highway, 4th doing ~70 @4k RPMs helped some, but eventually had to tone it back hitting 400 on the CHT gauge. I'd like that to be around 375 on flat highway in 5th doing 75 around 3500 rpm.
At least I know that the brake issue is resolved that I can delve into why the engine is not running as cool as I'd like. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:56 AM |
