After Market Blinker switch experience?, Does your switch cancel on its own? |
Steve |
Jun 15 2020, 07:39 AM
914 Guru Group: Members Posts: 5,611 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
My horn was going on and off on its own, so I bought a blinker switch to fix the problem.
I bought a blinker switch from Sierra Madre and one from Jbuggs. Both came in the same white box. Both fixed the horn problem and everything else works, but when you turn a corner, the blinker does not cancel on its own. Same steering wheel and horn ring which worked fine on the previous switch. I also noticed the cancel do hickey, does not stick out as far as the original one. Any recommendations for one that does cancel on its own? (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/wacko.gif) |
76-914 |
Jun 15 2020, 08:05 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
dr914@autoatlanta.com |
Jun 15 2020, 08:55 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
important that when you connect the turn signal switch to the wiper switch that both insert into the column very easily with no pressure and that the screws go all of th eway in not pulling the assembly down. If they are used to pull the assembly in then the switch will bind and the stalk not return
My horn was going on and off on its own, so I bought a blinker switch to fix the problem. I bought a blinker switch from Sierra Madre and one from Jbuggs. Both came in the same white box. Both fixed the horn problem and everything else works, but when you turn a corner, the blinker does not cancel on its own. Same steering wheel and horn ring which worked fine on the previous switch. I also noticed the cancel do hickey, does not stick out as far as the original one. Any recommendations for one that does cancel on its own? (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/wacko.gif) |
Steve |
Jun 15 2020, 10:46 AM
Thanks Doc!! Next time I pull the wheel, I will check it out again.
ClayPerrine |
Jun 15 2020, 11:47 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The last aftermarket switch I bought canceled just fine. But it would let out a loud SCREECH when turning the steering wheel.
I was ORDERED to put the old one back by the owner. (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/betty914.jpg) |
TheCabinetmaker |
Jun 16 2020, 06:58 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Lmao, Clay!
Lo-Fi Version | Time is now: 7th June 2024 - 02:24 PM |
