Help on 76, Fuel and vacuum lines |
Tz Toy |
Jun 15 2020, 01:54 PM
Newbie Group: Members Posts: 6 Joined: 15-June 20 From: Seattle'ish WA Member No.: 24,382 Region Association: Pacific Northwest |
New member, first post.
I inherited a 76, 914. Car hasn’t been driven much over the last 15+ years. Freshening things up (tune, fix oil leaks, replace fluids, fix a few electrical issues…). A coworker said I should replace the fuel lines through the tunnel with stainless. I’ve watched a couple videos of it done on a 74, but the layout looks different. The fuel filter and pump are under the fuel tank on mine. The plastic fuel lines look original. Has my car been modified or is this how the 76 comes? Any help with a vacuum line schematic would also be much appreciated. |
SirAndy |
Jun 15 2020, 02:55 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
New member, first post. I inherited a 76, 914. Car hasn’t been driven much over the last 15+ years. Freshening things up (tune, fix oil leaks, replace fluids, fix a few electrical issues…). A coworker said I should replace the fuel lines through the tunnel with stainless. I’ve watched a couple videos of it done on a 74, but the layout looks different. The fuel filter and pump are under the fuel tank on mine. The plastic fuel lines look original. Has my car been modified or is this how the 76 comes? Any help with a vacuum line schematic would also be much appreciated. '75/'76 had the fuel pump relocated under the tank, earlier cars had it in the rear under the engine shelf. The stainless steel fuel lines are the same for all years though and should work just fine with your car. (IMG:style_emoticons/default/bye1.gif) PS: (IMG:style_emoticons/default/welcome.png) |
fiacra |
Jun 15 2020, 03:03 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 338 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
There is good information on Jeff Bowlsby's web site. Not just vacuum hose diagrams, but a whole wealth of information and diagrams. https://bowlsby.net/914/Classic/TechNotebook.htm |
JeffBowlsby |
Jun 15 2020, 08:01 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
These will get you started. You should also have an EGR valve/vacuum line and your carbon canister is closer to the battery, but the plumbing should be the same.
Attached image(s) |
76-914 |
Jun 15 2020, 10:09 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Contact Robert aka @Rotary914 on this site. He makes the SS lines for us West Coast folks. He also has a video on how to install them. (IMG:style_emoticons/default/beerchug.gif)
Tz Toy |
Jun 16 2020, 09:37 AM
New member, first post. I inherited a 76, 914. Car hasn’t been driven much over the last 15+ years. Freshening things up (tune, fix oil leaks, replace fluids, fix a few electrical issues…). A coworker said I should replace the fuel lines through the tunnel with stainless. I’ve watched a couple videos of it done on a 74, but the layout looks different. The fuel filter and pump are under the fuel tank on mine. The plastic fuel lines look original. Has my car been modified or is this how the 76 comes? Any help with a vacuum line schematic would also be much appreciated. '75/'76 had the fuel pump relocated under the tank, earlier cars had it in the rear under the engine shelf. The stainless steel fuel lines are the same for all years though and should work just fine with your car. (IMG:style_emoticons/default/bye1.gif) PS: (IMG:style_emoticons/default/welcome.png) Much appreciate the info. Do you know of a kit or set of lines that run from the tunnel SS lines to the eng SS lines? Or do I just run rubber fuel line? |
Tz Toy |
Jun 16 2020, 09:51 AM
(IMG:style_emoticons/default/welcome.png) There is good information on Jeff Bowlsby's web site. Not just vacuum hose diagrams, but a whole wealth of information and diagrams. https://bowlsby.net/914/Classic/TechNotebook.htm Thanks. Love the parts books |
rhodyguy |
Jun 16 2020, 10:08 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Rotary'914 in the 'Member Vendor' subforum for line needs. Fuel pump and filter are located behind the cover on the trunk side of the front firewall/bulkhead.
dr914@autoatlanta.com |
Jun 16 2020, 10:18 AM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the lines are well protected and I would not go to the hassle to replace unless there has been welding done or the rear lines are broken.
New member, first post. I inherited a 76, 914. Car hasn’t been driven much over the last 15+ years. Freshening things up (tune, fix oil leaks, replace fluids, fix a few electrical issues…). A coworker said I should replace the fuel lines through the tunnel with stainless. I’ve watched a couple videos of it done on a 74, but the layout looks different. The fuel filter and pump are under the fuel tank on mine. The plastic fuel lines look original. Has my car been modified or is this how the 76 comes? Any help with a vacuum line schematic would also be much appreciated. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:27 AM |
