Rear spring rate of 52# per inch = what exactly? |
Tdskip |
Jun 15 2020, 06:19 PM
My hunch is that someone where has this memorized already - but 52 pounds per inch equates to 160 rear springs? They are blue.
BTW - going by the prior owners notes but he was an engineer so inclined to think they are correct. Thanks! |
PlaysWithCars |
Jun 15 2020, 10:31 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Um... a very saggy rear end. 160 rear springs refers to 160 lbs per inch. 52 is way lighter than anything that came from the factory. Suspect their either the wrong spring, the way they were measured was wrong or someone is remembering the wrong information.
Could it be that he measured them at 152 lbs/in and only reported the "52"? |
Mikey914 |
Jun 15 2020, 11:14 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Well our research has shown that they were actually tested out at between 52 (I suspect this was one of the older more worn ones) and 68 lb springs from the factory.
We determined that the optimum spring would be 100. Kind of like they de-tuned them right from the factory. It offers a good street ride. The 140 progressive 160 is good if you want something that is more track oriented but still street able. https://900designs-container.zoeysite.com/1...rear-spring-set Attached thumbnail(s) |
sixnotfour |
Jun 16 2020, 03:10 AM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Tdskip |
Jun 16 2020, 06:25 AM
Thanks - I also (embarrassingly) found a prior thread that I started with some related info.
I can't compress these by pushing down on them beyond a small initial movement, and not enough to get them on the rear springs, so agree they are more like;y 152 than 52. I appreciate the responses. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:48 AM |
