Sway Bar Bushings, Where to buy |
JOEPROPER |
Jun 16 2020, 08:43 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Where can I purchase 19mm front sway bar bushings? Is there a part # that I can search? Thanks. Joe-
6s7s&9s |
Jun 16 2020, 08:54 AM
Newbie Group: Members Posts: 9 Joined: 13-June 20 From: Bay Area California Member No.: 24,375 Region Association: Northern California |
New to 914s but I'd imagine a sway bar bushing is a sway bar bushing, I've had success with products from energy suspension
https://www.energysuspensionparts.com/9.5156 |
rhodyguy |
Jun 16 2020, 09:32 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,088 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Those bushings have no application on a stock thru body 914 front swaybar. None. I would enquire about the appropriate 19mm bar bushings at Paragon.
brant |
Jun 16 2020, 09:35 AM
914 Wizard Group: Members Posts: 11,633 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree with Kevin
most likely you have a weltmeister bar and need weltmeister bushings but lots of other brands out there too H and H etc, |
mepstein |
Jun 16 2020, 09:46 AM
914-6 GT in waiting Group: Members Posts: 19,308 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Wasn't 19m used on the Porsche 911 Turbo? If so, it should be available from any Porsche supplier.
JOEPROPER |
Jun 16 2020, 09:54 AM
Paragon is out of stock. @Mepstein What year?
mepstein |
Jun 16 2020, 10:58 AM
The early turbos used a through the body swaybar. ‘76 was the first year in the US. I don’t know how long that continued. |
914Sixer |
Jun 16 2020, 12:22 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
19mm was used on the 911's. Why not take a stock 914 bushing, put it in the bushing holder and drill it out to 19 mm (3/4")? IS 19 stamped on the the bar? Factory bars have numbers on one end.
bdstone914 |
Jun 16 2020, 12:55 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@JOEPROPER
date='Jun 16 2020, 08:54 AM' post='2825577'] Paragon is out of stock. @Mepstein What year? [/quote] Is this a thru body stock type sway bar? If it is a Welt Meister type bar they used a Delrin cylinder type bushing, PET shows an 18mm bar on turbo cars. 901 343 792 04. Call your local Porsche dealer. Retail is about $19 each. Pelican lists them at $17.75 |
Literati914 |
Jun 16 2020, 02:29 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
mepstein |
Jun 16 2020, 02:55 PM
I have both an H&H - 19mm and a 911 Turbo - 18mm. I had assumed they were the same but I just measured them and found the 1 mm difference. I plan on using the h&h so I’ll be in the market for bushings as well.
JOEPROPER |
Jun 16 2020, 03:07 PM
I'm going to try the 901 343 792 04 (thanks Bruce) from my Porsche dealer. I'll drill them out to 19mm as suggested above (thanks Mark) and give it a try. I'll report back when done.
JOEPROPER |
Jun 17 2020, 12:25 PM
901 343 792 04 Ordered these from Pelican Parts. Total with shipping is $49.85 Porsche dealer said that they needed to get them from Germany and the only dealer in the country was in Oregon. So now I'm waiting for them to show up at my door.
Mikey914 |
Jun 17 2020, 12:55 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We will eventually be dong the 19mm bars, that would include the bushings, just will be a few months before I can get the production on these done.
Mark |
Lo-Fi Version | Time is now: 4th June 2024 - 01:42 PM |
