lwells8433 |
Newbie ![]() Group: Members Posts: 4 Joined: 13-January 18 From: Los Alamitos Member No.: 21,796 Region Association: Southern California ![]() |
Does know of a good mechanic in aurora Colorado? I just moved here and need to find one. Please and Thankyou
kwyjibo |
Newbie ![]() Group: Members Posts: 4 Joined: 18-February 13 From: Colorado Member No.: 15,549 Region Association: None ![]() |
Does know of a good mechanic in aurora Colorado? I just moved here and need to find one. Please and Thankyou Welcome to Colorado Eisenbud's, which is right off the 8th Ave. exit from I25, is good. I've seen the other shops in the area there getting help from John and Jim. I don't know of anyone in Aurora. Depending what you need done, there are other not-so-obvious places around |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,011 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Eurosport and greg Johnson are also old hands at 914's and used to race one
and the best teener machinist in the country is in grand junction The Denver shops send all of their heads/motor work out to him anyways.... |
lwells8433 |
Does know of a good mechanic in aurora Colorado? I just moved here and need to find one. Please and Thankyou Welcome to Colorado Eisenbud's, which is right off the 8th Ave. exit from I25, is good. I've seen the other shops in the area there getting help from John and Jim. I don't know of anyone in Aurora. Depending what you need done, there are other not-so-obvious places around Thankyou I appreciate that, since I moved here after the winter I took the 914 out and front passenger brake is grinding bad and would lock up the tire if I press normal on the pedal. But if I don’t press the pedal there are no noises. The rotor and brakes pad are still in very good shape from when I restored it. So I don’t know if it’s the caliper or something else |
shelby/914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 804 Joined: 24-August 05 From: Foxfield, Co Member No.: 4,655 Region Association: Rocky Mountains ![]() ![]() |
Storz Garage also works on 914s and other air cooled Porsches. Good work but you have to pay for it.
Dan |
Lo-Fi Version | Time is now: 12th July 2025 - 11:11 AM |
