Centre / gauge console unit fit and wiring |
dt4 |
Jun 16 2020, 01:23 PM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
Sorry for the continuous questions but there is little by way of information over this side of the pond
I have been putting the console together and when I compared the gauge wiring harness to the wiring in the car there isn’t anything I can see that matches The car is a 75 1.8 Should the wiring be part of the harness at the dash end or engine end? Also the fit is way off The side panel is up against the accelerator pedal and the heater lever is no where near fitting through Photos to illustrate Thank you |
dt4 |
Jun 16 2020, 01:45 PM
dt4 |
Jun 16 2020, 01:50 PM
Looking back at my general wiring question it looks like those wires are for the console but then how would the wiring from the gauges feed through to those connectors
Oh this is twisting my melon man |
dt4 |
Jun 16 2020, 02:13 PM
I have found a pelican parts technical article that provides a lot of help
https://www.pelicanparts.com/techarticles/9...ter_console.htm I dont have the u bracket or the shift lever boot but the main thing is the angled heater lever that I need I would hope to be able to figure out the wiring from the article but the closeness of the unit to the accelerator pedal still concerns me The first thing I need is the angled heater lever |
scottthephotog |
Jun 16 2020, 09:40 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
Check the for sale threads and eBay for the parts you need. I found my heater lever on eBay for like $30 about a year ago.
Yes, the wires for the center console gauges do fit into the white plugs. It's just spade connectors with a plastic sleeve. The male connector is in the plastic sleeve, and the female end is the wires from the gauges. Just push the female connector into the opening and onto the male connector. The brown wire with the round connector attaches to the defroster light (plastic square next to the heater lever). As far as the upper u bracket that connects to the dash, my console was missing that as well. I never installed one. I haven't had any issues with the console moving. It's a snug fit. |
dt4 |
Jun 17 2020, 12:29 AM
76-914 |
Jun 17 2020, 09:30 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
There is a crappy console in the classifieds for sale. You could rob that piece as they seem to have fallen off the edge of the Earth. The heater lever is an on-off item that goes to earth and completes the circuit for the heater blower motor. There is a small harness for the console gages. They are plentiful. IIRC, the wiring schematic for the console gauges is on a separate page in the Haynes manual toward the end of the schematics section. (IMG:style_emoticons/default/beerchug.gif)
EDIT: I may have that lever. I'll look around this morning. If so, you can have it for shipping costs.Wait a minute. I can see the lever in your pic. You just need the red knob for it. The 2 console brackets will hold the console in the correct position so it won't touch the pedal but it is close. You'll get used to it. Also, that lever should center up once the console is properly attached. |
dt4 |
Jun 17 2020, 12:55 PM
scottthephotog |
Jun 17 2020, 10:28 PM
There's a gear in the clock that usually breaks. I've got 2 dead clocks that were supposedly working when I bought them. I gave up trying to find one and set mine to read 9:14.
dt4 |
Jun 18 2020, 12:26 AM
There's a gear in the clock that usually breaks. I've got 2 dead clocks that were supposedly working when I bought them. I gave up trying to find one and set mine to read 9:14. that might be where I end up The console fills the gap nicely and the voltmeter works (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:14 AM |
