Missing Relays, Should it start without the relays? |
fizz74 |
Jun 18 2020, 10:18 AM
Newbie Group: Members Posts: 3 Joined: 27-January 20 From: uk Member No.: 23,867 Region Association: England |
Hi
I have recently become the proud owner of 1973 914 1.7. It does need abit of work and I am a newbie to the 914. After some tinkering, I managed to start the Porsche and get it running although not for long. It sounds like fuel starvation and has a very noisy fuel pump. When I popped open the regulator plate for inspection, I noticed a few of the relays were missing, the Power supply relay and the Fuel pump relay? I've not had the chance to get the multi meter on it as the 914 is under covers and its been raining here in the UK for the past few days. I'm wondering how the 914 started without the Fuel pump relay? The fuel pump clearly works because I can hear it and the 914 started and ran, I actually drove it(on a private road)?? Any help would be much appreciated. Thanks |
SirAndy |
Jun 18 2020, 10:26 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Does it have carbs? I've seen it many times where people get power for the pump from somewhere else (even directly from the coil) when slapping carbs on a 914.
If it is still the original D-Jet, you need both of those relays. (IMG:style_emoticons/default/shades.gif) PS: Post some pics ... . |
fizz74 |
Jun 18 2020, 11:11 AM
Does it have carbs? I've seen it many times where people get power for the pump from somewhere else (even directly from the coil) when slapping carbs on a 914. If it is still the original D-Jet, you need both of those relays. (IMG:style_emoticons/default/shades.gif) PS: Post some pics ... . The heater blower relay is also missing?? No carbs still on D-Jet. Still wondering how it started?? |
SirAndy |
Jun 18 2020, 11:26 AM
Still wondering how it started?? Somebody probably hotwired the fuel pump ... (IMG:style_emoticons/default/popcorn[1].gif) |
Frankvw |
Jun 18 2020, 11:40 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Welcome to the 914 !
since you managed to start it and run it shortly means your pump can run somehow, so gets the power somewhere else. You mention the pump makes a lot of noise. Another signal that it gets power. |
Jonathan Livesay |
Jun 18 2020, 11:59 AM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Is the fuel pump in the engine compartment? It should be on the firewall below the engine shelf on the passenger side. When you find it check if it is connected by the original connector or just with a + wire and a ground wire. If it runs without the fuel pump relay it's got to be the latter. You only need the 2 middle relays for the car to run. The one that is there is the main power relay the other (missing) is fuel pump, the two end ones are for rear window defroster and heater fan in the engine compartment.
I would see if I could find the correct pump wires, the original connector should be a white plastic cylinder with two wires. It's about 1/2 inch in diameter and almost 1 inch long. If you find it and it's not plugged in try taking the other wires off and plugging in the original connector. Then put a relay in the empty middle socket and see if it runs. |
bbrock |
Jun 19 2020, 07:53 AM
FYI, the headlight motors use the same relays so you might be able to borrow one from up there for testing.
fizz74 |
Jun 19 2020, 08:13 AM
VaccaRabite |
Jun 19 2020, 08:20 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
FYI, the headlight motors use the same relays so you might be able to borrow one from up there for testing. Will be testing this tomorrow thanks for the info and help. I will let you know how i get on. You need to trace the wires to the fuel pump FIRST and figure out where it is getting power, and then unplug it from there. Otherwise putting a relay into the hole won't tell you anything since the pump gets its power elsewhere. You have some unfucking to do. Zach |
rhodyguy |
Jun 19 2020, 08:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Your relay board is a mess. 914sixer is selling refurbished and tested relay boards in the classifieds. Your FI harness has seen better days. In most cases, there is no simple fix for 'as found' cars with FI issues. Prepare to spend some money.
914_teener |
Jun 19 2020, 10:33 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
FYI, the headlight motors use the same relays so you might be able to borrow one from up there for testing. Will be testing this tomorrow thanks for the info and help. I will let you know how i get on. You need to trace the wires to the fuel pump FIRST and figure out where it is getting power, and then unplug it from there. Otherwise putting a relay into the hole won't tell you anything since the pump gets its power elsewhere. You have some unfucking to do. Zach (IMG:style_emoticons/default/agree.gif) +10 |
Lo-Fi Version | Time is now: 7th June 2024 - 04:21 AM |
