CSP Bellcrank linkage and Dellorto's, Hitting the stop boss? |
nditiz1 |
Jun 25 2020, 09:15 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I just received a new set of CSP Linkage to replace the hexbar setup. The hexbar might have been fine, but I wanted better. The best would have been tangerine, but I haven't found that money tree yet (IMG:style_emoticons/default/biggrin.gif)
Anyway, went to test fit the drivers side and I ran into a snag. The ball screw going through the cam is hitting the stop boss on the rear side of the carb. Now, I guess I could flip the carbs, ugh, but this is how they should be setup as it is a L and R pair with the vac port sitting where it is suppose to on the passenger over top of cyl #4. Has anyone else run into this issue? I guess I could go from a pull type to a push type and flip the cam to the bottom. It just seemed better if everything was in a pull motion as opposed to the cable pulling the pivot which pushes the butterflies. (IMG:http://live.staticflickr.com/65535/50045780601_1a2ce4ef73_c.jpg) |
IronHillRestorations |
Jun 26 2020, 05:21 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I can't tell from the pic, but you may have to swap the carbs
nditiz1 |
Jun 26 2020, 08:34 AM
Perry - I am trying to avoid that
By adding a washer and grinding down the screw end of the ball I am just clearing it. I may grind the cam a little to get more grip on the end nut as well as all little more space up top. So grinding the top of the cam on the inside closest to the carb barrel and then on the outside where the shaft nut tightens. I know I have seen weber cams have this bump out built in. This to me is something CSP should adopt in their kits as well. |
porschetub |
Jun 26 2020, 03:06 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Teryn It Up |
Jun 27 2020, 04:09 PM
Newbie Group: Members Posts: 6 Joined: 26-September 13 From: Monroe, Wa Member No.: 16,437 Region Association: Pacific Northwest |
I don't know if this will be helpful because I'm using webers but I am using the csp bell crank set up. And instead using the arms to pull the throttles I set them to push. I also used the cams that came on my webers instead of the csp cams.
nditiz1 |
Jun 27 2020, 07:48 PM
Thanks Teryn.
It's good to know you haven't seen any issues going to a push type method. I ordered some weber parts from pierce manifolds to stick on these Dells (IMG:style_emoticons/default/rolleyes.gif) They are the linkage parts that angle out so we'll see. Worst case I either go to a push type and drop the link piece to the bottom or go the route I currently have which is grind the link piece inside and trim the threads. |
porschetub |
Jun 28 2020, 03:16 PM
I don't know if this will be helpful because I'm using webers but I am using the csp bell crank set up. And instead using the arms to pull the throttles I set them to push. I also used the cams that came on my webers instead of the csp cams. That's correct,I now remember using genuine Dellorto arms as the were slightly longer,expect the Weber ones will be the same. I ditched the ball joints that my kit came with and used CB Performance ones. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:13 PM |
