So I just received a new set of CSP Linkage to replace the hexbar setup. The hexbar might have been fine, but I wanted better. The best would have been tangerine, but I haven't found that money tree yet
Anyway, went to test fit the drivers side and I ran into a snag. The ball screw going through the cam is hitting the stop boss on the rear side of the carb. Now, I guess I could flip the carbs, ugh, but this is how they should be setup as it is a L and R pair with the vac port sitting where it is suppose to on the passenger over top of cyl #4. Has anyone else run into this issue? I guess I could go from a pull type to a push type and flip the cam to the bottom. It just seemed better if everything was in a pull motion as opposed to the cable pulling the pivot which pushes the butterflies.
