> 911 Front Hub Information, Conversion Information
914Sixer
post Jun 26 2020, 05:13 PM
Just though I would post up some information for those doing 911 front hubs and the differences.
Replies(1 - 10)
Superhawk996
post Jun 26 2020, 08:10 PM
Awesome summary of hubs -- Thanks for posting.
(IMG:style_emoticons/default/first.gif)
andrewb
post Jun 27 2020, 01:54 AM
Very timely and useful information - thanks. I'm just trying to source another hub for my 5 lug conversion and thought all I had to check for was '47mm'.
Couple of extra questions if I may - firstly what's the significance of the .03 and .04 numbers ?
Secondly the 58mm and 71.5mm dimensions - do they locate into the centres of certain types of wheel ? I'm fitting cookie cutters for now.
Thanks
914Sixer
post Jun 27 2020, 06:41 AM
03, 04 just indicate different versions of hub. As shown, the 03 has small 55mm diameter bearing cover and the 04 has the larger 71.5 mm cover. Your cookie cutters will work with no problem.
bdstone914
post Jun 27 2020, 06:53 AM
bdstone914
@andrewb
' date='Jun 27 2020, 12:54 AM' post='2828507']
Thanks
[/quote]
The grease caps are different.
One goes inside of the raised boss and one goes over the boss. I may have a single i can sell. You could mix an 03 and 04 with no problems.
Bruce
sixnotfour
post Jun 27 2020, 10:38 AM
Hubcentric
brant
post Jun 27 2020, 10:49 AM
Off topic slightly ..... ?
How long are front studs supposed to be?
Tia
slivel
post Jun 27 2020, 10:58 AM
Old car....... older driver
Can you address any differences in wheel bearings or spindles that can be used?
andrewb
post Jun 27 2020, 02:56 PM
'914Sixer'
Thanks Mark.
'bdstone914'
Thanks to you also Bruce - that was my next question. And thanks for the offer but I'll try and find one this side of the pond. Just out of interest over here they seem to go for £75 to £150 depending on condition etc.
914Sixer
post Jun 27 2020, 08:06 PM
Stock length wheel bolts were 45 mm. Lots of other combinations depending of the spacers you are using.
bdstone914
post Jun 27 2020, 09:23 PM
bdstone914
@brant
' date='Jun 27 2020, 09:49 AM' post='2828599']
Tia
[/quote]
Standard studs are 45mm.
- Lo-Fi Version Time is now: 16th October 2025 - 02:50 AM
