anyone ever put....., a 944 motor in a 914? |
xsboost90 |
Jul 10 2005, 04:26 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
i mean it should be just like the 928 swap w/ a whole lot more room! Im thinking use a 944 trans though, might make for alittle more room, smoother shifts and correct gearing. Now how to figure out linkage?
Attached image(s) |
scotty b |
Jul 10 2005, 04:34 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I have given the tranny ALOT of thought for my 6 conversion, seeing as how I have 2 spares sitting around. I haven't gone as far as to pull one out and take measurements but the problems I imagine are A = mounting (probably not to hard) and B = input shaft may be too short. One possible fix for that ( I'm not sure I like it) is to make a short shaft and use the coupler the 944 uses to mate the tranny shaft and torque tube shaft.
jwalters |
Jul 10 2005, 04:47 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Sheesh Scotty, get something working right will ya.... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
scotty b |
Jul 10 2005, 05:09 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) My attitude werking just fine jackass (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif) How'd you make out with Dennis? 914 have enough clearance to navigate the streets? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Could I ask you to take a look at my CIS guru post and give any input you may have? Please? Pretty please with Miles on top??? Oh and the suburban run fine too, as does the 944 it just is taking a little longer than expected.......... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
rick 918-S |
Jul 10 2005, 11:04 PM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
944 motors have a big as distributor sticking off the front of the motor. With the length of the head and the added length of the distributor it would end up about a foot into the car. Way too much work for the HP gain. Better off just building a big type IV. Transaxle looks cool though.
scotty914 |
Jul 10 2005, 11:30 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
trans looks cool but no starter flange, look at the audi 5000 tranny, pretty strong and the shifter stuff has been figured out
rick 918-S |
Jul 10 2005, 11:36 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
Verruckt |
Jul 11 2005, 12:09 AM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
Yeah, I talked to Rick about this. This was my "big idea". Seemed cool as hell. But like he said, the distributor sticks way out. You would have to mod the firewall on the passenger side big time, very little room. God if there was a way to make it work, i'd be all over it. Would that tranny help any? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
rick 918-S |
Jul 11 2005, 12:23 AM
You may be able to get around the distributor issue with some kind of crank fire adapter and coil packs or something but the Hp gain still isn't worth all the work.
The transaxle has no starter provision. If the case is aluminum one could be cut and welded to the case easy enough. but...... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Brando |
Jul 11 2005, 01:07 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
That and you'd have to run the shift linkage through the motor. 944 trans have the linkage going into the top, unlike the 915 and 901 where it comes into the bottom/bottom side. |
Brett W |
Jul 11 2005, 09:27 AM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
The tranny is the same as the 016 from the Audi 5000 and 5000 turbo. Just build a cable shift.
andys |
Jul 11 2005, 01:40 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Unlike the Audi 016 (AAZ or 5N), the 944 016 (J/K/R/S) trans has no provision for a starter, or a clutch. The input shaft is all wrong. Also, the 944T trans parts (better ratio's, hardened 1st gear) will not interchange with the Audi 016, in case you were wondering.
Andy |
Lo-Fi Version | Time is now: 28th May 2024 - 11:29 PM |
