Fast idle |
Fast idle |
Robson51 |
Jul 20 2020, 11:18 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Got the car running again! New TPS and addition of Pertronix.
TPS set, timing on the mark at 3000 rpm. Idle sits at 1500 rpm. How do I lower it? Thanks- |
rjames |
Jul 21 2020, 02:02 AM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Find your vacuum leak.
... did you plug the vacuum hose to the distributor when you set the timing? Some info about your car will help people give informed help. Carbs or FI, etc. |
Robson51 |
Jul 21 2020, 08:33 AM
Find your vacuum leak. ... did you plug the vacuum hose to the distributor when you set the timing? Some info about your car will help people give informed help. Carbs or FI, etc. No, vacuum hose was unplugged as per Haynes. 2.0, original FI. That’s why it has a TPS. Rob |
DRPHIL914 |
Jul 21 2020, 08:47 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Find your vacuum leak. ... did you plug the vacuum hose to the distributor when you set the timing? Some info about your car will help people give informed help. Carbs or FI, etc. No, vacuum hose was unplugged as per Haynes. 2.0, original FI. That’s why it has a TPS. Rob ok so the line was off the distributor during the setting of the timing per Hanes, good, but was the line going back to the throttle body plugged so its not allowing a vac leak during that, and is itnow back connected, this will pull your idle back down to normal if it is not connected to the vac canister. - if all that is now connected, my guess is a vac leak somewhere else, or idle mix is too rich, also idle screw on the throttle body could be open or the AAr not closing, |
Robson51 |
Jul 21 2020, 09:31 AM
Find your vacuum leak. ... did you plug the vacuum hose to the distributor when you set the timing? Some info about your car will help people give informed help. Carbs or FI, etc. No, vacuum hose was unplugged as per Haynes. 2.0, original FI. That’s why it has a TPS. Rob ok so the line was off the distributor during the setting of the timing per Hanes, good, but was the line going back to the throttle body plugged so its not allowing a vac leak during that, and is itnow back connected, this will pull your idle back down to normal if it is not connected to the vac canister. - if all that is now connected, my guess is a vac leak somewhere else, or idle mix is too rich, also idle screw on the throttle body could be open or the AAr not closing, Yes, line was plugged. I’ll check the AAR and the mixture screw. Thanks! |
Lo-Fi Version | Time is now: 7th June 2024 - 10:23 PM |
