Tips on rust repairing this section? |
Tdskip |
Aug 15 2020, 09:30 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
dr914@autoatlanta.com |
Aug 15 2020, 09:32 AM
914 Guru Group: Members Posts: 7,875 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have the channel and the complete engine shelf with channel. First rust part we made back in the late 80s!!!
Aug 15 2020, 09:33 AM
rhodyguy |
Aug 15 2020, 09:34 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Source a dr side. Mirror image. I used a dr side when I repaired the hack job from the AC install.
mtndawg |
Aug 15 2020, 09:49 AM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I did this on my last car. If I recall correctly RD has the shelf with the channel for the rubber. Trim it to fit. Look at 2nd page of this thread to see the piece.
http://www.914world.com/bbs2/index.php?sho...=239002&hl= |
Tdskip |
Aug 15 2020, 11:25 AM
Thanks for the tips and responses.
It is somehow more exciting to order mechanical bits than replacement metal.... |
bbrock |
Aug 15 2020, 11:36 AM
I did this on my last car. If I recall correctly RD has the shelf with the channel for the rubber. Trim it to fit. Look at 2nd page of this thread to see the piece. http://www.914world.com/bbs2/index.php?sho...=239002&hl= Yes, RD has the shelf with channel and I think sells just the channel also so you have options. I installed a shelf on mine. It's a pretty easy install but you have to do a bit of fiddling and cutting to trim the piece for a perfect fit. |
Tdskip |
Aug 15 2020, 02:50 PM
I did this on my last car. If I recall correctly RD has the shelf with the channel for the rubber. Trim it to fit. Look at 2nd page of this thread to see the piece. http://www.914world.com/bbs2/index.php?sho...=239002&hl= Yes, RD has the shelf with channel and I think sells just the channel also so you have options. I installed a shelf on mine. It's a pretty easy install but you have to do a bit of fiddling and cutting to trim the piece for a perfect fit. Thanks @BBrock . I got the rear trunk panel welded in today so I think I’m gonna tackle this next while I work up the courage to deal with the jacking point. |
Lo-Fi Version | Time is now: 29th May 2024 - 03:47 AM |
