Cracked ignition switch replaced, still no start, What else could be wrong? |
rd914 |
Jul 12 2005, 12:15 PM
Newbie Group: Members Posts: 31 Joined: 13-April 05 From: San Diego, CA Member No.: 3,928 |
Screwdriver trick at solenoid starts the car so I replaced ignition switch but it did not fix the problem. Not even a click when I turned the key but all the lights and fuel pump come on. The seat belt buzzer box under passenger
seat has been disconnected and the yellow wires connected to bypass it per recommendation from previous posts. Suggestions? Thanks. |
Mueller |
Jul 12 2005, 12:32 PM
do you get 12vdc at the yellow wire when you turn the key??
rd914 |
Jul 12 2005, 01:24 PM
I will check tonight. What should I check if there is and if there is none.
Cap'n Krusty |
Jul 12 2005, 01:38 PM
What year is your car? The Cap'n
Mueller |
Jul 12 2005, 01:39 PM
if no voltage, you have to check the relay board, you have 2 connectors, one is a 12 pin, the other a 14 pin 14 pin connector #1 yellow, main trunk, starter wire from ignition switch 12 pin connector #6 yellow, starter solenoid if you have voltage at the #1 pin, yet no voltage at #6, you have a fault with the relay board or corrosion buildup on the pins. |
rd914 |
Jul 12 2005, 02:55 PM
Thanks Mike.
Cap'n, Car is a 76 2.0 |
scruz914 |
Jul 12 2005, 07:28 PM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
You may have voltage but not enough juice. Make sure the contacts (male and female) are clean and tight. You can split the male pin with a razor blade which will help tighten the connection. Also make sure the connections on the starter are clean and tight. -Jeff |
TravisNeff |
Jul 12 2005, 09:50 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Make sure your coil hasn't spun in the clamp, if you short a terminal on your tin, there is a black wire that runs to your ignition switch that is not fused and will melt out, ask me how I know. That was a pain to replace the wire, not to mention after the 3 ignition switches I replaced before I realized what I messed up.
Lo-Fi Version | Time is now: 8th June 2024 - 11:10 AM |
