| ctc911ctc |
Aug 19 2020, 07:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,319 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74 2.0 Side Shift (but you knew that)
OK, finishing up on the tranny rebuild (Thank you Dr Evil @dr_evil ) and I am not able to remove the shifter Selector Rod seal.......... ![]() ![]() I have tried using a seal remover, screwdriver, long-thin drift from the other side (wrong angle), a pick, a hammer and the screw driver, all while being careful trying not to marr the side of the seal housing. It almost seems as if there is a metal washer pressed into the hold on top of the seal...........weird...... Any ideas? Experiences? Incantations? |
| ctc911ctc |
Aug 20 2020, 08:52 AM
The Seal has been removed, Turns out that this seal (I am very certain the tranny case has never been opened before this) has a steel outer housing. Kind of like a bearing case.
I needed to deform and then pull it out........about 1.5 hours so I did not screw up the receptacle. Hole? ![]() ![]() ![]() |
| Frankvw |
Aug 20 2020, 09:15 AM
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
that was quite a fight yes ! ....but the new seal has only metal on the inside to make it stiff ?
| Mikey914 |
Aug 20 2020, 10:36 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yes it used a metal ring to hold it firmly in place.
| ctc911ctc |
Aug 20 2020, 01:19 PM
The one that came in the tranny gasket kit is not as bulletproof. Any advice as to this component?
All vendors seem to sell the same one - has anyone ever bought one with a steel case? |
Lo-Fi Version | Time is now: 18th March 2026 - 06:08 AM |
