> Clutch Install Problem, Pressure Plate Not Fitting Over Indexing Pins
Ansbacher
post Aug 20 2020, 11:19 AM
Trying to install my pressure plate on my '74 2.0L . All the bolt holes and indexing pin holes line up, but the indexing pins will not fit into their respective holes- pins are a tiny bit too large for the holes. Is it kosher to file down the pins or drill out the indexing holes a tad? Don't want to muck things up at this point. Need advice. Thanks.
Ansbacher
Replies(1 - 6)
jsaum
post Aug 20 2020, 11:25 AM
I wouldn't touch the pins. I would adjust the holes on the pressure plate. How much of a difference is there?
Ansbacher
post Aug 20 2020, 11:39 AM
QUOTE(jsaum @ Aug 20 2020, 01:25 PM) *
Barely one drill size difference.
Ansbacher
jcd914
post Aug 20 2020, 11:41 AM
(IMG:style_emoticons/default/WTF.gif)
The pins normally fit tight into the pressure plate.
I have never had to enlarge the pressure plate holes but I have had to add a little extra force to get the pins started through.
Jim
jsaum
post Aug 20 2020, 11:44 AM
I would get an exact size matched drill bit to the pins and open them up.
Mike D.
post Aug 20 2020, 12:01 PM
OK, It runs now, and pretty good too!
QUOTE(jcd914 @ Aug 20 2020, 10:41 AM) *
Jim
Never had to drill, just start the bolts and evenly tighten all the way around. They will go in...
Ansbacher
post Aug 20 2020, 03:58 PM
I solved this by lightly reaming out the indexing holes with a small round file. Thanks everyone.
Ansbacher
- Lo-Fi Version Time is now: 16th October 2026 - 06:01 PM
