| rmital |
Aug 23 2020, 03:13 PM
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,955 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
| Mark Henry |
Aug 23 2020, 03:18 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
It's located about half way up the fuel pump wire harness, over/near the hell hole.
| rmital |
Aug 23 2020, 03:23 PM
| IronHillRestorations |
Aug 23 2020, 03:25 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,950 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
It's in the engine compartment, below the battery.
What year is your car? |
| rmital |
Aug 23 2020, 03:31 PM
It's in the engine compartment, below the battery. What year is your car? '73 just finished replacing fuel pump and redoing fuel lines, hot as hell in the garage today....I'm exhausted...so had very little energy left to find the wire. charging battery now. I'll peek under battery when putting back in car. this wire provides the info to the temp gauge on console? was functional a month ago when last drove, so assuming I just knocked it off while replacing pump and working with pump power connection. |
Aug 23 2020, 04:46 PM
It's in the engine compartment, below the battery. What year is your car? '73 just finished replacing fuel pump and redoing fuel lines, hot as hell in the garage today....I'm exhausted...so had very little energy left to find the wire. charging battery now. I'll peek under battery when putting back in car. this wire provides the info to the temp gauge on console? was functional a month ago when last drove, so assuming I just knocked it off while replacing pump and working with pump power connection. Yes, it's a green/black wire for the temp gauge. It's a clear single spade connector body in the engine compaartment |
Lo-Fi Version | Time is now: 18th July 2026 - 06:48 AM |
