> Paint for black targa top
rosenfe
post Aug 23 2020, 03:14 PM
I plant to clean top,not sand. Any recommendations for spray paint choice in black
Replies(1 - 19)
IronHillRestorations
post Aug 23 2020, 06:55 PM
I. I. R. C.
Clean it with a strong mix of soap and water a couple times, maybe even add a little TSP in it if you've got it.
Then I'd go over it with solvent cleaner like PreSol, Klix88, or Acme Solvent cleaner. Use two rags, one with the solvent and the other to wipe off. Change rags as they get dirty and don't stop cleaning until you wipe and your wipe off rag is clean.
This doesn't mean you still won't have trouble with oil spotting, because you may. 45+ year old fiberglass roofs have be coated with Armorall, wax, shoe polish, silicone, and a host of other treatments that can impregnate the fiberglass. Your best pre-paint action is to clean, clean, and clean more.
In a perfect world, you'd use an catalyzed, flattened (to the right level of low sheen), automotive finish type paint, but that's not always practical.
I've got a car in my shop right now that needs the roof painted, and we're going to try a single stage rattle can epoxy VHT Epoxy All Weather Satin Black VHT Satin Black Epoxy I've been using it on suspension components and engine tins, and I like the finish and how it goes on. Time will only tell how durable it really is. Anything in a rattle can probably won't be as good as "real" auto paint, but ease of use is a plus. I get it from my local NAPA store. Online retailers may have it, but some really over charge for it
Tdskip
post Aug 23 2020, 08:48 PM
Super helpful post as usual, thanks @IronHillRestorations
Tonyooc
post Aug 23 2020, 08:59 PM
I sprayed mine with a product called Raptor. You can find it in paint shops or Amazon. I sprayed my valance and spoilers the same
Montreal914
post Aug 23 2020, 09:55 PM
PCH
post Aug 23 2020, 11:34 PM
After cleaning, sprayed mine with a rattle can. Used SEM Landau Black. Came out beautiful! But the plastic was so dry that it soaked up 3 cans of paint!
Lucky9146
post Aug 24 2020, 12:01 AM
Had great results with SEM Trim Black. Cleaned top with Prep-sol, no sanding, no primer, just right over the existing texture that was there. Provides a nice sheen but not shiny.
You must keep a wet edge, which is difficult with a rattle can, but can be done. You will need 2-3 coats.
Have received lots of complements on it. Good luck!
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg)
post Aug 24 2020, 03:49 PM
I. I. R. C.
QUOTE(Lucky9146 @ Aug 23 2020, 10:01 PM) *
That really looks nice! SEM stuff is good.
Nojoah
post Aug 24 2020, 05:46 PM
QUOTE(Lucky9146 @ Aug 24 2020, 02:01 AM) *
I second the SEM trim black. Mine turned out great as well, sprays nicely out of the can. I've also had similar results with the wurth trim black counterpart as well. You should be looking for a satin finish.
StarBear
post Dec 3 2022, 09:36 AM
QUOTE(IronHillRestorations @ Aug 23 2020, 07:55 PM) *
Thinking of my winter projects and painting my targa top - searched and found your suggestion. Mine is original, texture is fine but bunches of various spots over the years.
Was wondering - your suggestion is lots of soap and water: dishsoap? something milder? stronger? Also, a thread on Pelican suggests using alcohol. Your thoughts?
Like many others, the top has many years of treatment, black shoe polish, and lately small dots of black Sharpie, so probably lots of hidden pockets of gunk in the texture valleys.
Finally, I use Wurth Satin Black for trim - OK for the top, or do the SEM Trim Satin?
Thanks!
930cabman
post Dec 3 2022, 10:59 AM
If I recall correctly BBrock did his a year or so ago, I am unsure how to find it.
nivekdodge
post Dec 3 2022, 11:26 PM
Sem 39144 is the same trim black in qt liquid form.They also sell "hot rod black" in kits HR010 which would be the "Porsche" of semi gloss black , and its just me, but the least I would do is a red scotch brite pad.
Kevin
post Dec 4 2022, 07:20 AM
I. I. R. C.
@StarBear I suggest a stronger detergent than dish soap. Diluted Simple Green or Purple Power is going to clean better, tri sodium phosphate is really good too. Scrub with a soft bristle brush and rinse with clean water, at least twice. I used a commercial auto body cleaning solvent like Prep Sol or Klix 88 after that. Alcohol won’t cut wax and silicones good enough. I would use the scuff pads that are finer than the 3m red, I think they are gray.
I recently spoke with the owner of the car I used the spray can VHT satin black on, and he said it still looks good.
StarBear
post Dec 4 2022, 08:58 AM
QUOTE(IronHillRestorations @ Dec 4 2022, 08:20 AM) *
Thanks! Nervous about doing this, but at least a good cleaning is worthwhile.
Would a quart of Prep-Sol be enough? So far, have seen it only in gallons.
post Dec 5 2022, 07:19 AM
I. I. R. C.
QUOTE(StarBear @ Dec 4 2022, 06:58 AM) *
Probably won’t need more than a pint or two. Any good auto repair pre paint cleaner solvent will work.
mlindner
post Dec 5 2022, 08:00 AM
I need to paint mine also, but I need to get back to the original texture first. Any good product or techniques for that.
dr914@autoatlanta.com
post Dec 5 2022, 09:03 AM
if the top has been sanded smooth, you will have to duplicate the texture with WURTH SKS shot from a special gun
If only repainting, then Wurth semi gloss TRIM Paint
QUOTE(rosenfe @ Aug 23 2020, 02:14 PM) *
Root_Werks
post Dec 5 2022, 10:18 AM
Village Idiot
The top that came with my 914 was so bad, it was tossed. Sourced a decent one from @914Werke , cleaned it with soap and water. Then mineral spirits, then rattle canned SEM Trim Black.
Turned out way nicer than I thought it would. Sheen seems like a spot on match and it's held up very well so far.
Others have said already:
Clean and prep is key
If you rattle can, keep a wet edge
Have enough cans, 2 for me, 2 coats
windforfun
post Dec 5 2022, 07:47 PM
QUOTE(rosenfe @ Aug 23 2020, 01:14 PM) *
I didn't know that you could plant these things.
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif)
StarBear
post Dec 12 2022, 01:15 PM
Refresh done!
Followed suggestions posted here. Used liquid sandpaper to degloss, Simple Green followed by substitute TSP, SEM spray prep solv (1/2 can for 3 wipe downs), and SEM satin trim black (2 light coats followed by 1 medium coat; just short of one can).
Whew! Pleased with result. Was nervous about messing up the top.
Fortunately, texture was still fine.
- Lo-Fi Version Time is now: 15th March 2026 - 10:57 PM
