speedometer apart, all gears turn |
vertigo |
Jul 12 2005, 04:12 PM
Member Group: Members Posts: 72 Joined: 12-June 05 From: Porterville, Ca Member No.: 4,262 |
Thanks for advice on getting speedo out. I have removed cover and am looking at drive/worm gears at this moment. I used a cordless drill to operate speedometer up to about 45 m.p.h. and watched gears working, and I'll be darned if it all works again. While I have it apart is there anything I should look at? I see the drive and worm gears are plastic and in good shape {they will get grease). The gear on the odo shaft is metal. Do I need to go further in dismanteling?, or stop where I am and put back into car? Any help is appreciated as I am into new territory concerning speedo repair.
Mueller |
Jul 12 2005, 04:19 PM
the drive unit on the transmission is more likely the culprit....
Dave_Darling |
Jul 12 2005, 04:32 PM
Remember, the pot-metal gear is supposed to turn with its shaft, not turn on its shaft.
And like Mueller said--did you make sure the odo really was the problem? --DD |
vertigo |
Jul 12 2005, 06:47 PM
Odometer seems to be the problem. I ran the unit out of car again and while speed is good odo does not register. All seems to be turning, I marked the shaft on the odo drive gear and all seems to work corect, but mileage not registering. Could there be a problem in the tumblers? The unit works in the morning when first driven, but does not in afternoon. Any suggestions are greatly appreciated. If gear is turning on shaft how would I stop that?
bd1308 |
Jul 12 2005, 06:50 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
score the hell out of that shaft.....with a pair of needle-nose pliers.....and then put some epoxy on that sucker....
bperry |
Jul 12 2005, 08:03 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Yep its pretty much that simple. I didn't use any epoxy. I just
used a pair of wire cutters and GENTLY bit into the shaft to score it and then re-installed the gear. Never had any more problems. One word of caution. Be careful when handling the actual speedometer. My needle hit the stop and chipped off the tip of the red paint. I didn't notice this until AFTER I re-assembled it and crimped the trim ring. DARN..... I had to open it again and re-paint the needle. THEN, if that wasn't enough, months later, the enamel paint heated up and stuck to the post and then I had an odometer but no speedometer. I had to open it up AGAIN, and free the needle. --- bill |
Joe Ricard |
Jul 12 2005, 08:17 PM
No NO NOOOOOO
Look at the Pelican Parts article for fixing the Odometer. This really works and does it right. If you try epoxy it will only hold for a little while. IDONNO about pliers in the shaft maybe..... |
bd1308 |
Jul 12 2005, 08:25 PM
joe i got a truck.....i'm closer to coming....
ROAD TRIP :hijack: over |
Lo-Fi Version | Time is now: 8th June 2024 - 04:55 PM |
