| brcacti |
Aug 28 2020, 05:45 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, can I hear from someone who has don the odometer fix? Did you deform the gear as instructed in the pelican parts instructions?
| Nojoah |
Aug 29 2020, 07:54 AM
Member ![]() ![]() Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
Hello, can I hear from someone who has don the odometer fix? Did you deform the gear as instructed in the pelican parts instructions? Some decent pressure on the gear with a pair of needle nose pliers worked well for me. Fit tightly back onto the shaft and I've had no problems. |
| mepstein |
Aug 29 2020, 08:27 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,007 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Drop of superglue helps.
| brcacti |
From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear.
| PanelBilly |
Aug 29 2020, 08:33 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,998 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I did it years ago, It worked for awhile and then stopped.
| bdstone914 |
Aug 29 2020, 09:04 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,430 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@brcacti
' date='Aug 29 2020, 07:27 AM' post='2846887'] From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear. [/quote] I found no room to get any room to get pliers in there. I had another speedo and used the shaft from it to deform it. I was able to push out the original shaft with the other shaft to keep all the gears in place. |
| brcacti |
Aug 29 2020, 04:15 PM
Hello ALL, I have the odometer back together, is there a way to test it before I put it into the car ???????
| 76-914 |
Aug 29 2020, 06:11 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,993 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Took me 3 times before all of the digits aligned evenly. (IMG:style_emoticons/default/headbang.gif) Use a drill.
| porschetub |
Aug 29 2020, 07:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,203 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
[quote name='bdstone914' date='Aug 30 2020, 03:04 AM' post='2846892']
@brcacti ' date='Aug 29 2020, 07:27 AM' post='2846887'] From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear. [/quote] I found no room to get any room to get pliers in there. I had another speedo and used the shaft from it to deform it. I was able to push out the original shaft with the other shaft to keep all the gears in place. [/quote] Use the trip reset cable and run it backwards with a drill Bob. |
| brcacti |
Aug 29 2020, 08:41 PM
Took me 3 times before all of the digits aligned evenly. (IMG:style_emoticons/default/headbang.gif) Use a drill. Yeah, it's delicate and tricky working on those tomorrow I will try a drill on it to see if it works |
| brcacti |
Aug 29 2020, 08:42 PM
[quote name='porschetub' date='Aug 29 2020, 06:15 PM' post='2847002']
[quote name='bdstone914' date='Aug 30 2020, 03:04 AM' post='2846892'] @brcacti ' date='Aug 29 2020, 07:27 AM' post='2846887'] From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear. [/quote] I found no room to get any room to get pliers in there. I had another speedo and used the shaft from it to deform it. I was able to push out the original shaft with the other shaft to keep all the gears in place. [/quote] Use the trip reset cable and run it backwards with a drill Bob. [/quote] Thanks will try that in the morning with the drill, thanks to all that helped |
Lo-Fi Version | Time is now: 22nd November 2026 - 05:30 AM |
