Full Version: odometer fix who has done this?
brcacti
Hello, can I hear from someone who has don the odometer fix? Did you deform the gear as instructed in the pelican parts instructions?
Nojoah
QUOTE(brcacti @ Aug 28 2020, 07:45 PM) *
Some decent pressure on the gear with a pair of needle nose pliers worked well for me. Fit tightly back onto the shaft and I've had no problems.
Drop of superglue helps.
brcacti
From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear.
PanelBilly
I did it years ago, It worked for awhile and then stopped.
bdstone914
@brcacti
' date='Aug 29 2020, 07:27 AM' post='2846887']
[/quote]
I found no room to get any room to get pliers in there.
I had another speedo and used the shaft from it to deform it. I was able to push out the original shaft with the other shaft to keep all the gears in place.
brcacti
Hello ALL, I have the odometer back together, is there a way to test it before I put it into the car ???????
76-914
Took me 3 times before all of the digits aligned evenly. headbang.gif Use a drill.
porschetub
[quote name='bdstone914' date='Aug 30 2020, 03:04 AM' post='2846892']
@brcacti
[/quote]
[/quote]
Use the trip reset cable and run it backwards with a drill Bob.
brcacti
QUOTE(76-914 @ Aug 29 2020, 05:11 PM) *
Yeah, it's delicate and tricky working on those tomorrow I will try a drill on it to see if it works
brcacti
[quote name='porschetub' date='Aug 29 2020, 06:15 PM' post='2847002']
@brcacti
[/quote]
[/quote]
[/quote]
Thanks will try that in the morning with the drill, thanks to all that helped
