> odometer fix who has done this?, 1974 914 1.8
brcacti
post Aug 28 2020, 05:45 PM
Hello, can I hear from someone who has don the odometer fix? Did you deform the gear as instructed in the pelican parts instructions?
Nojoah
post Aug 29 2020, 07:54 AM
QUOTE(brcacti @ Aug 28 2020, 07:45 PM) *
Some decent pressure on the gear with a pair of needle nose pliers worked well for me. Fit tightly back onto the shaft and I've had no problems.
post Aug 29 2020, 08:27 AM
914-6 GT in waiting
Drop of superglue helps.
brcacti
From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear.
PanelBilly
post Aug 29 2020, 08:33 AM
I did it years ago, It worked for awhile and then stopped.
bdstone914
post Aug 29 2020, 09:04 AM
bdstone914
@brcacti
' date='Aug 29 2020, 07:27 AM' post='2846887']
[/quote]
I found no room to get any room to get pliers in there.
I had another speedo and used the shaft from it to deform it. I was able to push out the original shaft with the other shaft to keep all the gears in place.
brcacti
post Aug 29 2020, 04:15 PM
Hello ALL, I have the odometer back together, is there a way to test it before I put it into the car ???????
post Aug 29 2020, 06:11 PM
Took me 3 times before all of the digits aligned evenly. (IMG:style_emoticons/default/headbang.gif) Use a drill.
porschetub
post Aug 29 2020, 07:15 PM
[quote name='bdstone914' date='Aug 30 2020, 03:04 AM' post='2846892']
@brcacti
[/quote]
[/quote]
Use the trip reset cable and run it backwards with a drill Bob.
brcacti
post Aug 29 2020, 08:41 PM
QUOTE(76-914 @ Aug 29 2020, 05:11 PM) *
Yeah, it's delicate and tricky working on those tomorrow I will try a drill on it to see if it works
brcacti
post Aug 29 2020, 08:42 PM
[quote name='porschetub' date='Aug 29 2020, 06:15 PM' post='2847002']
@brcacti
[/quote]
[/quote]
[/quote]
Thanks will try that in the morning with the drill, thanks to all that helped
- Lo-Fi Version Time is now: 22nd November 2026 - 05:20 AM
