First drive today!, Video added ---- Doesn't stay in gear |
BPic |
Aug 30 2020, 12:19 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Hi everyone, After 2.5 years I have finally driven my 914. (IMG:style_emoticons/default/piratenanner.gif)
Runs good but needs some dialing in with the timing and carbs. But, I have to hold the shifter to keep it gear 1st, 2nd, and 3rd. Didn't go any faster to hit 4 and 5. Is this adjustable with the standard shift adjuster or is there another issue going on? (IMG:style_emoticons/default/confused24.gif) Thanks all and I'll post video of the maiden run soon. Brad |
Al Meredith |
Aug 30 2020, 12:52 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Brad, Is it a tail shifter or a side shifter? I would say a tail shifter might be able to adjust the linkage and replace the bushings but the side shifter maybe not because the have a more direct linkage. I've got a 901 gearbox all rebuilt on the bench now just waiting for someone to tell me if they want a tail or side shift internal linkage installed. AL
BPic |
Aug 30 2020, 01:20 PM
Brad, Is it a tail shifter or a side shifter? I would say a tail shifter might be able to adjust the linkage and replace the bushings but the side shifter maybe not because the have a more direct linkage. I've got a 901 gearbox all rebuilt on the bench now just waiting for someone to tell me if they want a tail or side shift internal linkage installed. AL Hi Al, Guess I should have said it’s a side shift. All new everything except the trans. Bought it from a member. Looking at the adjustment procedure it seems Odd that 1st and 2nd would pop. If I adjust either way it seems I might get one or the other but not both. Just in case can you send me a PM with a price for your trans? Thanks |
BPic |
Aug 31 2020, 06:14 AM
bbrock |
Aug 31 2020, 11:02 AM
(IMG:style_emoticons/default/piratenanner.gif) That's awesome!!! I hope you can get the shifting sorted out.
Lo-Fi Version | Time is now: 31st May 2024 - 11:15 PM |
