Shift coupler, How tight is yours? |
nditiz1 |
Sep 1 2020, 11:40 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So with my shift rod out and modified for my -6 (Thanks to Ben!) I was checking my coupler for play. I didn't notice any issues before removing the engine/trans, but since it's out I thought I would ensure it's good to go. I have only replaced the bushings once in my 911 and I cannot remember how tight the swivel was post installed. Mine seems very tight (that's what she said), but maybe that is a good thing. Should it be difficult to move by hand, maybe just needs some grease.
dr914@autoatlanta.com |
Sep 1 2020, 11:46 AM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
assemble with lithium grease, The 914 shift coupler bushings have a perfectly round hole so no slop, the 911 bushings are slightly slotted for movement, as the engine being in the rear and torquing up would move the shifter in your hand if not for the built in factory slop
So with my shift rod out and modified for my -6 (Thanks to Ben!) I was checking my coupler for play. I didn't notice any issues before removing the engine/trans, but since it's out I thought I would ensure it's good to go. I have only replaced the bushings once in my 911 and I cannot remember how tight the swivel was post installed. Mine seems very tight (that's what she said), but maybe that is a good thing. Should it be difficult to move by hand, maybe just needs some grease. |
nditiz1 |
Sep 1 2020, 11:52 AM
Thanks George sounds like everything is in spec. I'll apply some grease.
DRPHIL914 |
Sep 1 2020, 12:13 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i have the bronze bushings and its super tight, but moves smoothly when shifting.
Lo-Fi Version | Time is now: 6th June 2024 - 02:53 AM |
