Front Strut Top Mounting, Query on Fastening |
wysri9 |
Oct 6 2020, 07:43 AM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
My new front strut insert came with a Nylock nut for the top mounting. The old insert had the large support washer with tab, a small tab washer (which was bent up to prevent rotation of the nut, and a plain threaded 14 x 1.5 nut - no Nylock.
So what is the collected wisdom.....nylock yes or no, and with or without small tab washer?? One of these went on fine with both the large support washer and the small tab washer, but the second one has now twice refused to make up chewing up the small tab washer twice and the large support washer once. (IMG:style_emoticons/default/headbang.gif) Seems excessive torque is getriiing into the washers......Is it just a lubrication issue...?? Any guidance much appreciated. Thanks in advance. S |
914Sixer |
Oct 7 2020, 07:02 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I am a fan of the tab washer. They are cheaply made and can easily be filed on. I like the old factory way. Maybe a dab of anti-seize. I am still out about nylock nuts. They scare me on tie rod ends.
wysri9 |
Oct 7 2020, 07:04 AM
I am a fan of the tab washer. They are cheaply made and can easily be filed on. I like the old factory way. Maybe a dab of anti-seize. I am still out about nylock nuts. They scare me on tie rod ends. Thats the way I was erring - I'll go with that! Thx for response! (IMG:style_emoticons/default/beerchug.gif) S |
IronHillRestorations |
Oct 7 2020, 07:15 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I do both, nyloc and tab washer
Krieger |
Oct 7 2020, 08:22 AM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
On my race car I mark many of the nuts position with either a sharpie or a dab of white out where the threads meet the nut. Check these marks from time to time to develop confidence.
Lo-Fi Version | Time is now: 1st June 2024 - 06:12 AM |
