Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
I was once again test driving my car and while cruising along at 30~40 mph I heard a loud non continuous scraping noise; almost like a tire rubbing against a curb. I stopped to inspect and saw nothing. Everything was clean. No rub marks.
I pushed down on the suspension a few times and that seemed to help so I could limp home, but the noise started to get worse as I drove more. Probably drove a mile to get home. Looking for some guidance cause a have no idea. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,122 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@Highland
Take the wheel off and inspect more closely. Look for rub marks on tire. Could be a wheel bearing, shot trailing arm bushings. With weight off the wheel see if you have top to bottom play and/or side to side. |
KSCarrera |
Member ![]() ![]() Group: Members Posts: 337 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England ![]() |
Worst case scenario: suspension mounting console broken away from chassis leg (hell-hole rust?). Broken spring?
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,788 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I once had a noise like that and it ended up being a stone caught between the dust cover and the brake rotor. The noise it made sounded like my wheel was going to come off.
Pull the wheel for sure and give everything a solid look. Zach |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,800 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) I'd check that brake shield first. (IMG:style_emoticons/default/beerchug.gif)
pt_700 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,110 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California ![]() ![]() |
get that wheel in the air and spin.
when the rear wheel bearing on my car went many years ago, i coulda described the noise like that. |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,968 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
yes could be just the brake shield. It happened to me in SoCal WCR Palm Spring.
Hope just minor issue. |
Lo-Fi Version | Time is now: 18th September 2025 - 05:02 PM |
