| Robson51 |
Oct 10 2020, 10:20 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
I’ve read the posts about opening up the Auxiliary Air unit, and I have one that I’ve opened for a 2.0 D-Jet.
My problem is the wIre. Mine is broken off, way up inside the casting. Is there a way to reattach it? Any tips on what to do or not do? |
| Superhawk996 |
Oct 11 2020, 08:01 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,192 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I’ve read the posts about opening up the Auxiliary Air unit, and I have one that I’ve opened for a 2.0 D-Jet. My problem is the wIre. Mine is broken off, way up inside the casting. Is there a way to reattach it? Any tips on what to do or not do? I had an AAR with intermittent short and tried to peel back the portion of the steel ferrule that covers the wire when it exits the main body. I did this using a lathe and I still failed to get an acceptable fix that I would trust. I eventually disassembled the whole thing just to see what was inside. Not very promising to fix if it broke off up inside that ferrule. ![]() Mabye someone else has good advice for us. AA has "rebuilt" units but pricey at $285+200 for core. Here was someone that succeeded. http://www.914world.com/bbs2/index.php?sho...c=70865&hl= |
| Robson51 |
Oct 11 2020, 09:42 AM
I’ve read the posts about opening up the Auxiliary Air unit, and I have one that I’ve opened for a 2.0 D-Jet. My problem is the wIre. Mine is broken off, way up inside the casting. Is there a way to reattach it? Any tips on what to do or not do? I had an AAR with intermittent short and tried to peel back the portion of the steel ferrule that covers the wire when it exits the main body. I did this using a lathe and I still failed to get an acceptable fix that I would trust. I eventually disassembled the whole thing just to see what was inside. Not very promising to fix if it broke off up inside that ferrule. ![]() Mabye someone else has good advice for us. AA has "rebuilt" units but pricey at $285+200 for core. Here was someone that succeeded. http://www.914world.com/bbs2/index.php?sho...c=70865&hl= Thanks for the link. I was hesitant to drill out the rivets without knowing what I was getting into. On another note, does anyone else find the Search function lacking? I don’t have much luck finding what I’m looking for. |
| Superhawk996 |
Oct 11 2020, 10:58 AM
Use google
Site: 914world.com and then whatever you want to search |
Lo-Fi Version | Time is now: 25th November 2026 - 12:53 PM |
