| simonjb |
Oct 12 2020, 02:02 PM
KiwiMan ![]() ![]() ![]() Group: Members Posts: 574 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States
I am installing the engine tin etc. I believe this spring is also held by a piece of metal that is attached to the top of the fan housing with the hex nut. I also assume the spring end goes under not over the plate. But is the spring to be 'Loaded" such that it has tension? I know the thermostat wire attaches also....
| sholman5 |
Oct 12 2020, 02:19 PM
Kraut burner ![]() ![]() Group: Members Posts: 196 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States
| iankarr |
Oct 12 2020, 02:38 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,596 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Yes, the end of the spring goes under the post. It's under slight tension in its "resting" state...which corresponds with the flaps in the fully-warm position. When cold, the thermostat retracts, causing the cable attached to the bar to pull down, putting the spring under (more) tension. This way if the thermostat fails, the bar snaps back to the full warm position to prevent the engine from overheating. I think it's easier to attach the cable when the engine is fully warm. Just pull the cable taught and secure with the set screw.
| JeffBowlsby |
Oct 12 2020, 03:35 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,236 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
You also need the rubber grommet for the wire passing though the hole in the tin.
| simonjb |
Oct 12 2020, 03:46 PM
Thanks all....Does that black tab have a part number?
| cary |
Oct 12 2020, 11:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
021119729A NLA
We just make them out of 20ga. |
| bbrock |
Oct 13 2020, 07:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I cut mine out of a salvaged piece of steel pallet strapping. Can't claim credit for the idea, another member suggested it. There are two tabs used. One by the spring, the other at the opposite end of the rod.
Lo-Fi Version | Time is now: 16th April 2026 - 11:33 AM |
