Backdating Rear, Clip removal |
jim_hoyland |
Oct 13 2020, 01:11 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’ve read all the threads that show removing the clips; they are giving me a fight. Here’s a pic of 1st clip. I used a Blair spot weld cutter on the top weld, then pried the clip a little so I could get my Dremel between the clip and the body. Took forever to cut through. Second pic is the body.
Am I missing something ? Last pic is the other side, which I haven’t started yet ***Pics are out of order Attached thumbnail(s) Attached image(s) |
JOEPROPER |
Oct 13 2020, 02:30 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Spot weld cutter can be tricky. You have to be careful not to make a hole... I used a spot weld cutter and grinder very slowly.
BillJ |
Oct 13 2020, 03:07 PM
Senior Member Group: Members Posts: 1,106 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
If used properly and carefully the spot weld bit should not make a hole. Go slow and drill out each one. Looks like you are doing fine except for the hole. I did the rears without error but did one hole on the front. Just go slowly.
dakotaewing |
Oct 13 2020, 03:21 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Put painters tape on that paint so you don't scratch paint that you don't want to scratch.
DRPHIL914 |
Oct 13 2020, 03:38 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Spot weld cutter can be tricky. You have to be careful not to make a hole... I used a spot weld cutter and grinder very slowly. (IMG:style_emoticons/default/agree.gif) mainly just used the grinder |
jim_hoyland |
Oct 13 2020, 04:30 PM
Thanks for those tips (IMG:style_emoticons/default/smile.gif)
Doing the other side in the am Attached image(s) |
rgalla9146 |
Oct 14 2020, 05:19 PM
Advanced Member Group: Members Posts: 4,561 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Drill a small guide hole for each spot weld.....only through the clip. Position the guide hole so that the outside diameter of the cutter cannot reach the fender.
Grinding may be necessary after the "clip" is removed, not to remove it. |
jim_hoyland |
Oct 14 2020, 07:15 PM
Got the pass side Clip off. Sand a little and primed. I'll post pics in the am.
jim_hoyland |
Oct 15 2020, 07:50 AM
Pass side got 3x coats of primer yesterday, gonna sand with 600, then 1000 grits and then add base oat color. Never done this before, any tips ?
Driver side got the hole filled and some light sanding. Gonna sand and prime today. This side seems a little rougher. Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 11:33 AM |
