| dax1969 |
Oct 14 2020, 03:58 AM
Member ![]() ![]() Group: Members Posts: 400 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None
Hi guys,
I am going to install the turbo tie rod kit on my 74. Read all I could find but had a question on the flat key to be used. The one on autoatlanta is square but I can't seem to find them here. Would the below "rounded" one work ? Size is 32 mm so that should be correct thks Dax Attached image(s)
| betz |
Oct 14 2020, 09:44 AM
Member ![]() ![]() Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
Hi guys, I am going to install the turbo tie rod kit on my 74. Read all I could find but had a question on the flat key to be used. The one on autoatlanta is square but I can't seem to find them here. Would the below "rounded" one work ? Size is 32 mm so that should be correct thks Dax I'm no expert, but I didn't really need any special tools to do the tie rod conversion. I might've used a knipex wrench? But I imagine a crescent wrench or appropriately size box wrench would do the job just fine. I'm sure the tool you have will work as well. |
| bdstone914 |
Oct 14 2020, 11:30 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,207 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi guys, I am going to install the turbo tie rod kit on my 74. Read all I could find but had a question on the flat key to be used. The one on autoatlanta is square but I can't seem to find them here. Would the below "rounded" one work ? Size is 32 mm so that should be correct thks Dax It needs to be a thin 32mm the flat part of the turbo tie rod is very narrow. A crescent wrench will not work |
| 914e |
Oct 14 2020, 12:45 PM
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region
Snap-on sells thin blade wrenches, of course at a Snap-on price.
| Luke M |
Oct 14 2020, 12:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,443 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Check your local bike shops. I purchased one from such place and it worked great on two turbo installs . Save yourself some cash too.
| digit3 |
Oct 14 2020, 01:11 PM
Newbie ![]() Group: Members Posts: 36 Joined: 23-November 19 From: Tucson Member No.: 23,665 Region Association: Southwest Region |
| mbseto |
Oct 14 2020, 02:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Surprised you can get those anymore. Everyone uses sealed bearings. My old bicycle toolbox is filled with all the various BB sizes needed to repack all the bearings on the old Cannondale.
| iankarr |
Oct 14 2020, 02:35 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,582 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Got mine on amazon...
Park Tool Headset Wrench... https://www.amazon.com/dp/B001VRF0TM?ref=pp...op_mob_ap_share |
| mepstein |
Oct 14 2020, 04:56 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,281 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Surprised you can get those anymore. Everyone uses sealed bearings. My old bicycle toolbox is filled with all the various BB sizes needed to repack all the bearings on the old Cannondale. Cheap bikes still use the old standards. The park wrenches are good but not designed to crank down on the hardware. When you use them on a bike headset, you hold the 32mm flat on the bearing race while you crank down on the top nut with a large adjustable wrench. If you put a lot of torque on a thin spanner wrench, you end up rounding off the edges. |
| Olympic 914 |
Oct 14 2020, 06:42 PM
![]() ![]() ![]() Group: Members Posts: 1,765 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
I went to a local bicycle shop and used their wrench.
| bigkensteele |
Oct 14 2020, 08:30 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
I don't recall who, but a member here was selling laser cut wrenches for stock and turbo tie rods. I bought one and it is great. You might want to search the member vendor forum.
| mgp4591 |
Oct 14 2020, 11:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,832 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I bought my set years ago to replace Chrysler inner tie rod ends... I recently used them to change my turbo tie rod ends.
https://www.google.com/aclk?sa=L&ai=DCh...GRA9&adurl= |
| dax1969 |
Oct 15 2020, 01:38 AM
The one shown in my picture is actually used for bikes and is very thin. Will give it a try, cost is cheap.
thks yr feedback guys |
Lo-Fi Version | Time is now: 7th December 2025 - 08:55 PM |
