Windshield washer system, Converting |
Morph914 |
Oct 14 2020, 08:05 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I took the steering column apart today to familiarize myself with the windshield washer system. It appears that the PO converted the system to a pump from the the parts I found in one of many boxes of parts that came with the car when I bought it.
I would like to utilize the existing control on the column to operate the washer if possible. After watching Sir Andy’s video, it would appear that I can run a lead off of this black / brown wire that runs to the relay, to the washer pump and then just ground it near or at the pump. And then I’m thinking about mounting the pump in this area, but hoping that someone will chime in to verify that I can do this or any thoughts on a better way |
Ian Stott |
Oct 15 2020, 04:38 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
My teener has that, it is mounted on the other side of the hose which puts it underneath the reservoir out of sight, either spot is fine.
Ian Stott Moncton Canada |
Morph914 |
Oct 15 2020, 05:22 AM
Morph914 |
Oct 15 2020, 10:00 AM
What I am really looking to confirm is the wiring for the pump. Can someone verify that I can run a lead from the brown / black wire pictured over to the pump.
And will this allow me to run the washer from the lever on the column? Thank you, John |
FlacaProductions |
Oct 15 2020, 01:13 PM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
FlacaProductions |
Oct 15 2020, 01:15 PM
This seems to confirm as well: https://bowlsby.net/914/WiringHarnesses/Wip...nstructions.pdf
Coondog |
Oct 15 2020, 01:35 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Removed my nozzles when I painted my 914. Cleaner look and really who gets there 914 so dirty you need to use a WW that just smears the bug guts.
Opps just saw the OP is from Florida, ok you guys have bugs the size of birds... (IMG:style_emoticons/default/lol-2.gif) |
Morph914 |
Oct 16 2020, 08:41 AM
Thank you, but just wondering if anyone that already has the wiper interval set up like me has actually powered their electric pump with the brown / black wire. |
Morph914 |
Oct 16 2020, 08:53 AM
Removed my nozzles when I painted my 914. Cleaner look and really who gets there 914 so dirty you need to use a WW that just smears the bug guts. Opps just saw the OP is from Florida, ok you guys have bugs the size of birds... (IMG:style_emoticons/default/lol-2.gif) I do like the clean look without the nozzles. I grew up in so cal. and the bugs here in north Florida are not much worse than Cali, especially if you are driving to the river or other desert destinations. We do have some nasty little bugs a couple times a year called love bugs. They get the name because they fly around while mating. I always tell my wife, I want to come back as one of these, what better way to go if you splat on a windshield! (IMG:style_emoticons/default/grouphug.gif) They are bad for your paint though, I believe they have a bit of an acidic makeup and will do damage to the paint if not removed. Cheers, John |
DRPHIL914 |
Oct 16 2020, 09:04 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I took the steering column apart today to familiarize myself with the windshield washer system. It appears that the PO converted the system to a pump from the the parts I found in one of many boxes of parts that came with the car when I bought it. I would like to utilize the existing control on the column to operate the washer if possible. After watching Sir Andy’s video, it would appear that I can run a lead off of this black / brown wire that runs to the relay, to the washer pump and then just ground it near or at the pump. And then I’m thinking about mounting the pump in this area, but hoping that someone will chime in to verify that I can do this or any thoughts on a better way I am going to be doing this soon when i get my new pump and the new signal arm from 914sixer, and in order to use the stock wiper lever, i am going to try to install this switch from Carmagic http://carmagic.us/washer.html so the switch will be triggered by the stock lever but the nose will no longer be hooked up to the column but rather just from washer bottle to the pump, and pump to squirters. Good luck with your project. it will be nice to actually have squirters working. |
914Toy |
Oct 16 2020, 09:39 AM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
My teener has that, it is mounted on the other side of the hose which puts it underneath the reservoir out of sight, either spot is fine. Ian Stott Moncton Canada Thank you Mount it under your reservoir so that the pump is gravity fed. |
Morph914 |
Oct 16 2020, 02:11 PM
I just purchased the switch from carmagic as well, so I elect you to install your system first so I can copy, or not copy, what you do with yours.
FlacaProductions |
Oct 16 2020, 02:42 PM
I installed the Carmagic switch - just follow their instructions - no problem.
Morph914 |
Oct 16 2020, 07:13 PM
Lo-Fi Version | Time is now: 8th June 2024 - 12:21 AM |
