75 914 2.0 sittin along time Update! |
Slipry |
Oct 20 2020, 06:16 PM
Newbie Group: Members Posts: 20 Joined: 15-September 20 From: New Jersey Member No.: 24,693 Region Association: North East States |
Just a little update! took tank out. had alot brown sht mud in sump. all clean now Had injectors out and bench cleaned WOW! what a difference, runs great Accelerates smooth,no more Poppin/Fartin Only thing still idles at 1400 Warm no obvious vaccum leaks Where should i look first??? Thanks again guys í ½í¸Ší ¼í¿
porschetub |
Oct 20 2020, 07:41 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Just a little update! took tank out. had alot brown sht mud in sump. all clean now Had injectors out and bench cleaned WOW! what a difference, runs great Accelerates smooth,no more Poppin/Fartin Only thing still idles at 1400 Warm no obvious vaccum leaks Where should i look first??? Thanks again guys ������������ Well done getting it going,but in real terms a high idle is the sign of an air leak...keep looking pretty sure you will find some,have you tried to adjust the air fuel screw in the throttle body ?. Good luck. |
Gint |
Oct 20 2020, 09:45 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Just keep after replacing old hoses and you'll probably find it along the way.
Root_Werks |
Oct 21 2020, 11:51 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Just keep after replacing old hoses and you'll probably find it along the way. (IMG:style_emoticons/default/agree.gif) |
ctc911ctc |
Oct 21 2020, 12:25 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Pressure test the throttle body - this one evaded me for 2-3 trips around the "could-Be" tree......
Lo-Fi Version | Time is now: 7th June 2024 - 06:29 PM |
