i'm freggin pissed |
bd1308 |
Jul 14 2005, 06:52 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
is there any way to take a leaking pushrod tube seal and do something (short of replacing it) to make it no longer leak?
Mueller |
Jul 14 2005, 06:55 PM
drain the oil
install a vac. pump to create negative crankcase pressure |
SirAndy |
Jul 14 2005, 06:58 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
take it out, clean it, put it back in ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
bd1308 |
link me to a vac pump......
scotty b |
Jul 14 2005, 07:01 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Sounds like to me your car has a SERIOUS case of A.D.D. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Push rod tubes, then oil cooler, then pressure switch, then push rod tubes all in 2-3 days
Trekkor |
Jul 14 2005, 07:05 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Just turn this into a bigger maintenance project. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Replace the leaking seal. ( Or, go big and replace all the seals ). Change the oil, filter and adjust all the valves. Spend two or three hours and get some things done. KT |
Lo-Fi Version | Time is now: 7th June 2024 - 10:11 AM |
