Electrical Issues, Electrical Issues |
Slam254 |
Oct 31 2020, 08:30 AM
Newbie Group: Members Posts: 14 Joined: 1-September 20 From: Orinda, CA Member No.: 24,647 Region Association: Northern California |
Just got my ‘73 2.0 out of the shop. Engine rebuilt and new hoses and fuel lines, brake refresh, etc. idles and runs like a dream (IMG:style_emoticons/default/smile.gif)
*they had to do some electrical work to get the horn and all the lights working* So now there’s an annoying problem: The two blinker lights at the top of the tachometer go on (red sold light, not blinking) and an annoying buzzer noise goes on. When I pull the hazard light knob on the left, the green hazard light comes on and the buzzing stops. When I signal to turn left and right, the buzzing stops. The buzzing is driving me slightly crazy. Anybody ..... ? |
JeffBowlsby |
Oct 31 2020, 10:01 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
What shop would release a car in that condition? Let’s us know so we can avoid them.
dr914@autoatlanta.com |
Oct 31 2020, 10:11 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would say you have a short to back feed the relay, this is common. Disconnect one light assembly at a time and see what makes the buzzing stop, that is the miswired assembly. Always remember that any brown wire is a ground wire and must not be attached to a hot lead
Just got my ‘73 2.0 out of the shop. Engine rebuilt and new hoses and fuel lines, brake refresh, etc. idles and runs like a dream (IMG:style_emoticons/default/smile.gif) *they had to do some electrical work to get the horn and all the lights working* So now there’s an annoying problem: The two blinker lights at the top of the tachometer go on (red sold light, not blinking) and an annoying buzzer noise goes on. When I pull the hazard light knob on the left, the green hazard light comes on and the buzzing stops. When I signal to turn left and right, the buzzing stops. The buzzing is driving me slightly crazy. Anybody ..... ? |
914_7T3 |
Oct 31 2020, 12:19 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
If I understand correctly, this sounds like a bad relay for the turn signals, flashers and e brake. When the red e-brake light does not flash, the relay will buzz.
It may also be the connections in the relay holder are not making proper contact and needs to be reseated. The relay can be found by lowering the fuse box. These are similar issues to what I experienced on my ‘73. |
Slam254 |
Oct 31 2020, 01:09 PM
If I understand correctly, this sounds like a bad relay for the turn signals, flashers and e brake. When the red e-brake light does not flash, the relay will buzz. It may also be the connections in the relay holder are not making proper contact and needs to be reseated. The relay can be found by lowering the fuse box. These are similar issues to what I experienced on my ‘73. Oh shoot. I think I know what the problem is. If the parking break lever isn’t all the way down to the floor when released, the buzzer goes off to tell the driver that the parking break is still “on”. I will take it out this afternoon. But I think that’s what happened. THANK YOU for your comment !!!!! |
Oct 31 2020, 03:20 PM
should not buzz
Lo-Fi Version | Time is now: 7th June 2024 - 02:26 PM |
