DMAYHALL |
Newbie ![]() Group: Members Posts: 13 Joined: 26-June 14 From: las vegas Member No.: 17,557 Region Association: None ![]() |
Purchased a new GT front valance from AA. I have 7" front fiberglass flares. The GT valance does not fit !!! I have some wiggle room to play with fitment, but i will have to cut the " wings " and pull them in almost an inch on both sides. Has any gone through this before ??? Thanks !
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,322 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
98% of fiberglass needs lots of work to fit correctly.
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
Par for the course.
As pointed out already, some fettling with fiberglass GT panels is almost inevitable. The most painful item for my build were the GT rocker panels; as I decided to keep the old school fiberglass flares that were already fitted to the car, the rockers as delivered looked great - no imperfections, super stiff and well made; but were short by around 1/2" each side. Adding that 1/2" back in was many days work..... - Tony |
ValcoOscar |
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,393 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California ![]() ![]() ![]() |
Very common to trim/modify GT type fiberglass rockers or valances to fit as all flares are not installed the same.
I did a set of rockers for @914Boss a month ago. I also just did my rear GT valance (for Chucky) two weeks ago. Time-consuming, but easy. (IMG:style_emoticons/default/beer3.gif) You'll need: Fiberglass Resin, mat, Everglass fiberglass filler with fibers, glaze putty, sand paper, etc... Oscar |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
All my GT fiberglass parts required extensive "Tweaking" to get to fit properly.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The LE Fiberglass is made for a non flared LE car. You need to order parts for a flared car. Bad news is there are many flared options so unless your parts are part of a "kit" made to go together ( like the Sheridan kit), they will require reworking to fit.
eric9144 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California ![]() ![]() |
Its kind of sad how bad the glass stuff for GT's are, both the front dam/valence but especially the rockers, the rockers are a mess. Hoping that 914rubber can help there when they get going with all their composites stuff...
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
I think stock steel flares are 8", so that sounds about right.
Lo-Fi Version | Time is now: 15th June 2024 - 11:50 AM |
