Cables, To lube (or not to lube) questions - lend me your ears |
MM1 |
Nov 9 2020, 07:00 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I'm about to tackle some cables - can you please advise regarding lube? What type do you prefer (lithium, teflon,dry, etc) or do you prefer nothing?
I bought 914Rubber cables/sheaths for frunk, engine lid and clutch (cable kit). Terry cable from Pelican for accelerator. Just read @earossi 's post on the frunk (the pro's say lube, but not what type): http://www.914world.com/bbs2/index.php?showtopic=243445 Regarding clutch, I've read here and on Pelican (as well as motorcycle/bicycle forums) both "don't lube" and (for 914's) "only lube the roller", etc. I appreciate your guidance, as always. |
IronHillRestorations |
Nov 9 2020, 08:19 PM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
No lube on clutch and accel, but if I did it would be the dry spray. Problem is when it traps grit.
I'd use lube on hood and engine release cables |
MM1 |
Nov 9 2020, 09:17 PM
Thank you-what kind of lube would you use on hood and engine lid release cables?
mepstein |
Nov 9 2020, 09:24 PM
914-6 GT in waiting Group: Members Posts: 19,282 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
porschetub |
Nov 9 2020, 10:23 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
not required.
MM1 |
Nov 10 2020, 12:14 AM
Olympic 914 |
Nov 10 2020, 08:21 AM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Used AeroKroil on all the cables.
Good stuff. |
Nov 10 2020, 11:48 AM
I don’t like any petroleum based penetrating fluid for plastic lined cables, it can be hard on the plastic
MM1 |
Nov 10 2020, 12:49 PM
Lo-Fi Version | Time is now: 23rd May 2024 - 06:58 AM |
