Installing ss fuel lines - DELETE |
dax1969 |
Nov 10 2020, 12:25 PM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
YOU MAY DISREGARD THE BELOW
FOUND MY ANSWER IN IAN’S VIDEO Hi guys, I am about to install the tangerine ss fuel lines on my 2.0 74 (pump is relocated to the front near the steering rack) In the instructions I noticed that the longer line goes to the supply and when I follow that line back to the front firewall under the gastank I see a 9,5 mm on the passenger side and a 8 mm on the driverside. Am I correct to say that 9,5 mm is supply and 8 mm is return ? On fb somebody said that the 8 mm is supply and 9,5 mm is return (for his 1,8 liter). Fyi both new lines are 8 mm so just need to know which side is supply and which one is return.... Don’t want to screw it up Thks Dax |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:42 PM |
