Old side targa seals usually a pain to remove? |
Tdskip |
Nov 10 2020, 02:15 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi - I believe the answer is yes but I wanted to ask if original targa top side seals (where the windows wind up to meet) are usually a pain to remove.
I had one set that I was able to pull out but on the Fresno car they are good and stuck. Razor blade to cut some of the material so I can pull it off the metal rails that hold it in place a good approach? Thanks! |
Montreal914 |
Nov 10 2020, 02:20 PM
Senior Member Group: Members Posts: 1,563 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Why not cutting across with a blade all the way down to the metal, then use that opening to go in and pry it out of the rail with a flat screwdriver? Haven't tried, just thinking... (IMG:style_emoticons/default/confused24.gif)
Edit: I guess we are saying the same thing... (IMG:style_emoticons/default/biggrin.gif) |
Tdskip |
Nov 10 2020, 02:21 PM
Why not cutting across with a blade all the way down to the metal, then use that opening to go in and pry it out of the rail with a flat screwdriver? Haven't tried, just thinking... (IMG:style_emoticons/default/confused24.gif) Hi there. I think that’s what’s going to take, I just want to make sure I’m not missing anything else holding it in place. |
Montreal914 |
Nov 10 2020, 02:40 PM
Aren't the aluminum rails pinched on the rubber at one or both end like the vertical ones?
Tdskip |
Nov 10 2020, 03:22 PM
Tdskip |
Nov 10 2020, 06:13 PM
Got it done, they were just hard as rock. Flat bladed screwdriver on either side and pry up.
Thanks! |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:37 AM |
