Sachs performance or regular clutch 914, Which to buy and why |
Mcraneiowa |
Nov 11 2020, 08:14 PM
Member Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
I noticed online a Sach performance and Sachs regular clutch kit. Priced about $30 more for the performance version. Both show six springs, I can’t really tell the difference. Any suggestions? Price is $344.00 for the performance kit.
Also will Be replacing the flywheel, as it is scored. My car is a 74. 1.8L. The clutch system appears original to the car. Anyone know the best deal out there? Looking for suggestions. Thanks. |
porschetub |
Nov 12 2020, 12:07 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I noticed online a Sach performance and Sachs regular clutch kit. Priced about $30 more for the performance version. Both show six springs, I can’t really tell the difference. Any suggestions? Price is $344.00 for the performance kit. Also will Be replacing the flywheel, as it is scored. My car is a 74. 1.8L. The clutch system appears original to the car. Anyone know the best deal out there? Looking for suggestions. Thanks. The performance version most likely has more clamping force and IMO not needed for your car,good luck. |
cali914 |
Nov 12 2020, 12:15 PM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
Whats the weight difference? I would pick the lightest one if possible.
targa72e |
Nov 13 2020, 11:52 PM
Member Group: Members Posts: 263 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I have used both on recent (same car) 6 conversions engine installs. I used the standard clutch and it worked fin to hold power from 911 2.4 E spec motor (140HP at wheels). I keep the same disk but used sport pressure plate with 911 2.7 RS+ motor (204hp at wheels) I installed recently. Sport has held that power fine so far. If you have a stock 4 I would use standard as it is more than capable for stock power.
john |
914Sixer |
Nov 14 2020, 06:47 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Stock
Lo-Fi Version | Time is now: 5th June 2024 - 11:10 AM |
