Koni red's NLA for 914s? |
Tdskip |
Nov 18 2020, 07:30 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Can't seem to find new front Koni red inserts. I've heard mention that the 911 Koni reds fit and work fine but would like to get confirmation on that before diving in.
Anyone else come across this recently? Thanks, hope it's been a decent week so far. |
914_7T3 |
Nov 18 2020, 08:25 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Koni still makes adjustable sport shocks for the 914, only they are yellow. Got mine from Pelican. Hope this helps.
Tdskip |
Nov 18 2020, 08:51 PM
914_7T3 |
Nov 18 2020, 10:46 PM
Koni still makes adjustable sport shocks for the 914, only they are yellow. Got mine from Pelican. Hope this helps. Hi there! I thought yellow were Sport and stiffer than the red ones, no? My bad, yes reds are softer but adjustable as well. My car is set up with a set of restored Koni reds in the rear and yellows up front And it drives amazing! (IMG:style_emoticons/default/driving.gif) |
Tdskip |
Nov 18 2020, 10:51 PM
My bad, yes reds are softer but adjustable as well. My car is set up with a set of restored Koni reds in the rear and yellows up front And it drives amazing! (IMG:style_emoticons/default/driving.gif) What setting do you have the fronts on? Thanks for the feedback. |
914_7T3 |
Nov 18 2020, 11:01 PM
My bad, yes reds are softer but adjustable as well. My car is set up with a set of restored Koni reds in the rear and yellows up front And it drives amazing! (IMG:style_emoticons/default/driving.gif) What setting do you have the fronts on? Thanks for the feedback. Firm (IMG:style_emoticons/default/shades.gif) |
live free & drive |
Nov 19 2020, 05:33 AM
Member Group: Members Posts: 158 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
You can take a pair of Koni yellow top adjustable struts and have PSI revalve them for the red shock profile and take the gas out. At that point they are red struts, but with top adjustability. There is not a ton of difference between the two rebound profiles the red goes softer and does not get quite as firm. Cost $800
Tbrown4x4 |
Nov 19 2020, 05:39 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I had reds on the rear, and the seals went away. No parts available. Two shops could rebuild them for more $$ than a set of new yellow Konis. I bought the yellows and they are set on 2 clicks from full soft with 140 lb springs. They feel good to me, and seem to have no bad characteristics at my daily driver level.
I still need to do the fronts after a spindle drop. |
zulu33 |
Nov 19 2020, 06:40 AM
Newbie Group: Members Posts: 10 Joined: 24-May 15 From: Germany Member No.: 18,755 Region Association: Germany |
I had reds on the rear, and the seals went away. No parts available. Two shops could rebuild them for more $$ than a set of new yellow Konis. I bought the yellows and they are set on 2 clicks from full soft with 140 lb springs. They feel good to me, and seem to have no bad characteristics at my daily driver level. I still need to do the fronts after a spindle drop. Hi, there are only the yellow ones left in the Koni line. Gas shocks (Y) are adjustable at the top and harder than reds. If you want red, buy used and send them to Koni. I use the yellow ones in front and they are not too hard. Cheers |
sixnotfour |
Nov 19 2020, 08:25 AM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
call AA they remade stock ones
Tdskip |
Nov 19 2020, 08:28 AM
Thank you for all of the responses.
So it sounds like the easiest and most cost-effective thing to do is to just buy the yellow ones and set them on a fairly soft setting? I’m asking in context of a daily driver so I wanna make sure that the ride is enjoyable for full day outings. |
live free & drive |
Nov 19 2020, 08:37 AM
At the end of the day I think that will be fine - if you compare the two rebound curves it would be like the red adjusters set 20-25% off of the soft setting (using yellows at full soft)
GregAmy |
Nov 19 2020, 08:43 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
call AA they remade stock ones (IMG:style_emoticons/default/agree.gif) They just worked out a production run of the stock Boge parts, and the price is VERY attractive. http://www.autoatlanta.com/Porsche-914-911...1434190300.html http://www.autoatlanta.com/Porsche-Boge-Sa...1433305102.html http://www.autoatlanta.com/Porsche-911-912...33341S8500.html http://www.autoatlanta.com/Porsche-914-Fac...33341S8500.html If'n I didn't already have Koni Yellows all the way around - I'm a Koni butt-boy and race on them - then I'd be buying that last package. |
914Sixer |
Nov 19 2020, 09:51 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Koni Classic Reds for 911 are a drop in fit even though they are not listed. Several listed on Ebay and else where.
Tdskip |
Nov 19 2020, 10:00 AM
914Sixer |
Nov 19 2020, 11:23 AM
Yes, valving is good for 914 since you can adjust the shock.
Tdskip |
Nov 19 2020, 11:25 AM
Yes, valving is good for 914 since you can adjust the shock. Excellent - thank you, super helpful. OOPS - should have clarified that I see this listed for 1965-1974 cars but different part numbers. Correct that long hood car years likely the best match from a weight POV? |
Tdskip |
Nov 22 2020, 06:44 AM
live free & drive |
Nov 22 2020, 11:50 AM
if you want to be able to adjust the red shocks from the top you can find one of these tools ( no longer made) or make one yourself as they are fairly straightforward:
Tdskip |
Nov 23 2020, 09:39 AM
if you want to be able to adjust the red shocks from the top you can find one of these tools ( no longer made) or make one yourself as they are fairly straightforward: Handy tool, I have not seen it before. Thank you for posting. Any other experiences with the yellow or reproduced Boge struts? |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:41 PM |
