spare time toys |
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region ![]() |
Remember when we cut it down it had some high and low spots. I tried to do the sandind down with a chunk of T angle that was 3" wide and 1" thick. I kept getting a low spot I could not work out. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Before I trashed it and took too much off I stopped. I figured I needed a flat plate to sand it on. We had a bunch of these 1/4 inch plates we were tossing out at work and I got to thinking (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) I used a counter bore about 3/4 dia, and put a hole in the center. Cam wanted in on the action so I figured he could hold the drill as well as I can (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) It took a little while bu he got it done. We did a quick test fit on the input shaft to be sure it had some space so it didnt screw up the shaft.
Attached image(s) ![]() |
spare time toys |
We then cleaned it up and put some sanding discs on it and stood the trans on end with the input shaft in the new hole. We spun it a couple of times and checked. it took about 30 spins and the trans fits on the adapt, plate with no gaps. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) If you ever cut another one let me know and Ill send it up to you. I would think it may be a good thing to use on a regular trans to make sure the front face is true. I am not sure how they mount though.
spare time toys |
I did a quick test fit. You may want to make your next head a little smaller or move it up some.
spare time toys |
no gaps down here
spare time toys |
or up here (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
spare time toys |
I was just thinking I should have kept the dust from sanding this thing down and tried to light it off. Isnt it suposed to be mag. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Mag, Aluminum, they both are oxidizers.
Aluminum is the number one ingredient in Thiakol solid rocket fuel. Burns gud! Ken |
Lo-Fi Version | Time is now: 1st August 2025 - 04:34 PM |
