| bkrantz |
Dec 11 2020, 06:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,821 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I am about to start installing the plumbing and wiring on my bare body shell, and figure to start with things that go in the tunnel. I have ready:
brake line fuel lines accelerator cable clutch cable speedo cable wiring harness From past experience, any words of wisdom on the best order? |
| Bucci |
Dec 11 2020, 07:30 PM
Bucci ![]() ![]() Group: Members Posts: 123 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California
I would do;
Brake line Fuel lines Wiring harness Speedo cable Clutch cable Throttle cable You have to be careful that the throttle cable doesn’t get wrapped around the clutch cable which I’ve had happened several times. You’ll know this is incorrect when you push on the clutch and you’ll get minor movement from the throttle pedal..! |
| Maltese Falcon |
Dec 11 2020, 11:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,456 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
| jcd914 |
Dec 11 2020, 11:54 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I would leave the cables out until the engine is in, seen several new cables mangled during other work.
Jim |
| gcrotvik |
Dec 11 2020, 11:56 PM
Member ![]() ![]() Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I would do; Brake line Fuel lines Wiring harness Speedo cable Clutch cable Throttle cable You have to be careful that the throttle cable doesn’t get wrapped around the clutch cable which I’ve had happened several times. You’ll know this is incorrect when you push on the clutch and you’ll get minor movement from the throttle pedal..! Agreed. This is the order it come apart. |
Lo-Fi Version | Time is now: 17th November 2026 - 08:14 AM |
