Speaking of Transmission Repair, Help Identify The Mystery Tool |
Superhawk996 |
Dec 27 2020, 10:02 AM
914 Guru Group: Members Posts: 5,906 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I bought a tool from another member that was represented as a P225 equivalent engagement tooth removal tool. Unfortunately it is not an equivalent.
The width of the land that is supposed to mate in the circlip groove of the engagment teeth is too wide. Internal diameter is appropriate and the 2nd part that would be used to press the gear body is the right diamater. It's just that the land width is too wide to be used on 901 gear sets. Tool is marked BTU P284S. Doesn't really show any signs of prior use. Guess I know know why it was unused. (IMG:style_emoticons/default/headbang.gif) Google not turning up any real info. Wondering if this might be a tool for 915 1st gear but honestly I've never worked on a 915 trans so I have no point of reference about what is different with a 915 1st gear. I only know it is different. Anyway, I could modify the tool on my mill to work but honestly, it just pisses me off to have to modify a tool when I thought I was buying a P225 equivalent tool and the time it will take to set up and modify is more lost time & effort than just buying a new P225 tool. Anyone know what the tool is? Literally looks just like a P225 too. @Dr Evil |
Dr Evil |
Dec 27 2020, 11:24 AM
915 P226 for some of the lower gears in a 915.
Attached thumbnail(s) |
Montreal914 |
Dec 27 2020, 12:29 PM
Senior Member Group: Members Posts: 1,592 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I notice the P225 on the left has the same dog teeth marking on it as mine does after using it. I was concerned after I used mine a while back then figured the steel on the tool is softer than the gear box part, but still...
Why didn’t they made the tool so it would clear the teeth? (IMG:style_emoticons/default/confused24.gif) |
Dr Evil |
Dec 27 2020, 01:25 PM
I notice the P225 on the left has the same dog teeth marking on it as mine does after using it. I was concerned after I used mine a while back then figured the steel on the tool is softer than the gear box part, but still... Why didn’t they made the tool so it would clear the teeth? (IMG:style_emoticons/default/confused24.gif) Mine is 16yrs old and has been very well used, like over a thousand times (IMG:style_emoticons/default/wink.gif) |
Superhawk996 |
Dec 27 2020, 01:38 PM
@Dr Evil Thanks for response.
I guess it will remain a mystery since P226 tool looks to have a larger ID than P225. I can't find any Google hits on this paperweight. Probably some China made imitation of a P225 made improperly with the wrong land width to fit 901 dog teeth. (IMG:style_emoticons/default/sad.gif) By the way -- your video is both informative and entertainment. Love some of the one liners you slip in there! (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/aktion035.gif) |
altitude411 |
Dec 27 2020, 04:23 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
ebay add is no longer up... I did find this little bit on the bird.
http://forums.pelicanparts.com/porsche-911...tml#post7419176 |
Dr Evil |
Dec 30 2020, 11:50 AM
@Dr Evil Thanks for response. I guess it will remain a mystery since P226 tool looks to have a larger ID than P225. I can't find any Google hits on this paperweight. Probably some China made imitation of a P225 made improperly with the wrong land width to fit 901 dog teeth. (IMG:style_emoticons/default/sad.gif) By the way -- your video is both informative and entertainment. Love some of the one liners you slip in there! (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/aktion035.gif) Glad you like the DVD (IMG:style_emoticons/default/smile.gif) I looked all around and cant find a mention of that tool or number in any type of catalog for any make or model. Any pics or measurements? |
Lo-Fi Version | Time is now: 12th June 2024 - 12:03 AM |
