Best way to remove tranny front seal, Best way without scoring on 74 |
Mcraneiowa |
Dec 27 2020, 03:28 PM
Member Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
JOEPROPER |
Dec 27 2020, 05:13 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Screw in a self tapper and slide hammer or pry it out. I never did this on a 914, but have done it on many others. Just be careful.
cary |
Dec 27 2020, 05:56 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Here's what Super In Law and I came up with.
Custom seal puller. So it fits inside the bell housing. Quick and dirty. But ...................... Rest the lever on a scrap of flat steel so you don't dent/knick the outer edge. The arrow shows the spring rim. That's about where I go in. |
Bucci |
Dec 27 2020, 09:00 PM
Bucci Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California |
New design on the custom seal puller..!
porschetub |
Dec 28 2020, 12:49 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Screw in a self tapper and slide hammer or pry it out. I never did this on a 914, but have done it on many others. Just be careful. That's what I did, just make sure you don't drill in to far and only put the screw in far enough to get a good "bite" on the seal,you may need to drill 2 holes,not sure as mine came out with one. I used an install tool I made years ago for T1 swingaxle and IRS box's. |
Mcraneiowa |
Dec 29 2020, 06:21 AM
I purchased a seal puller and within seconds, okay a minute had the old one in my hand. A solid $15 investment to make sure I didn’t mess up the sealing surface. Thanks for the suggestions.
Lo-Fi Version | Time is now: 2nd June 2024 - 12:47 PM |
