| partwerks |
Jan 13 2021, 08:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,642 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Any pictures of location where the factory rear swaybar backing plates, and "Z" shaped brackets get welded on?
This is on a 1975. |
| 914werke |
Jan 13 2021, 09:36 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,762 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Pretty straightforward. There are two holes in the brace that spans the trunk floor.
They should have plastic caps in them but many have gone missing. The Weld nut fits up into that hole On the late cars you dont use the Z shaped bracket but a more simple Tang with weld nuts |
| Chris914n6 |
Jan 13 2021, 09:40 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,556 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
75-76 doesn't get Z brackets or the reinforcement plate. That particular spot was changed for the bumper shock. It gets a flat plate with the 2 nuts in the precut 2 holes.
| partwerks |
Jan 13 2021, 10:18 PM
Seems like in the past when I seen pictures, the backing plate was welded in the trunk, and the Z bracket goes on a stiffener on the bottom of the trunk??
https://duckduckgo.com/?t=ffhp&q=porsch...g&ia=images https://duckduckgo.com/?t=ffhp&q=porsch...g&ia=images https://duckduckgo.com/?t=ffhp&q=porsch...g&ia=images |
| Chris914n6 |
Jan 14 2021, 01:17 AM
| partwerks |
Jan 19 2021, 07:31 PM
They thought I had a 74, and sent me the wrong ones, but I guess I can just cut off the inner bend, and can continue from there.
Lo-Fi Version | Time is now: 2nd October 2026 - 01:45 PM |
