Fuel tank Question. |
Olympic 914 |
Jan 14 2021, 03:49 PM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Can you remove the fuel tank with the front trunk lid still in place, or must the lid be removed.
BillJ |
Jan 14 2021, 03:52 PM
Senior Member Group: Members Posts: 1,112 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Not required. Comes out without interference.
ClayPerrine |
Jan 14 2021, 03:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,523 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You do have to tilt it slightly forward as you raise up the tank. Otherwise you will scratch the underside of the front trunk.
If you remove the lid and set it on top of the car it makes it much easier, but it is not required. Use a sharpie to scribe around the hinges so you can get it back in the same place. Clay |
mepstein |
Jan 14 2021, 04:17 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’ve removed and replaced the tanks in a lot of cars and never removed the hood. If you are worried about scratching the inside of the hood, just tape a piece of cardboard to it. You always risk damaging ng the hood anytime you remove and replace it.
Olympic 914 |
Jan 14 2021, 04:38 PM
Lo-Fi Version | Time is now: 10th June 2024 - 12:11 PM |
