Oil Pickup Bolt/Stud? |
Boothy |
Jan 27 2021, 08:55 AM
Member Group: Members Posts: 92 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Ok, I'll approach the bench.
Haven't done a T4 since the 70s. Everything looks good but I'm a little baffled by the bolt for the oil pickup. Was that a stud or is it a bolt? I've read not to go beyond 9lbs which is fine. I'm just going through the pile of hardware wondering what it was. Was it a bolt or did I back out a locked up stud by mistake? This was a '72 1.7. |
Mark Henry |
Jan 27 2021, 09:11 AM
It's a closed nut, the stud is welded into the pickup and an eye goes through a bolt, so no way can you back out a stud.
Boothy |
Jan 27 2021, 09:19 AM
It's a closed nut, the stud is welded into the pickup and an eye goes through a bolt, so no way can you back out a stud. Thanks Mark! So once the case goes together, the bolt goes in from the outside through the the eye bolt on the pickup? I was so excited because the case finally went back together, everything turned nicely, flipped it over "BUGGER!" |
Mark Henry |
Jan 27 2021, 01:18 PM
Post a pic.
The stud sticks out of the oil pick up tube, the pickup tube (and baffle) is installed before you put the case together. |
Boothy |
Jan 27 2021, 01:29 PM
Thanks!
I found it. The oil pickup and windage tray are in place together. It was the bolt from the outside that threw me -couldn't find it. Went down at lunch and there it was. Ughhh. Thanks for your help! |
Lo-Fi Version | Time is now: 15th June 2024 - 11:20 AM |
